Help Center/ Cloud Container Engine/ Best Practices/ Auto Scaling/ Auto Scaling of Multiple Applications Using Nginx Ingresses
Updated on 2025-04-27 GMT+08:00
Deploying applications in multiple pods in a production environment can enhance their stability and reliability, but it can also lead to increased resource waste and costs. To strike a balance between resource utilization and application performance, manually adjusting the number of pods may not be efficient or effective.
However, if the application uses Nginx ingresses to route and forward external traffic, you can configure HPA policies using the nginx_ingress_controller_requests metric. This allows for dynamic adjustment of pods based on traffic changes, optimizing resource utilization.
  • The NGINX Ingress Controller add-on has been installed in the cluster.
  • You have installed the Cloud Native Cluster Monitoring add-on in the cluster and enabled Local Data Storage for the add-on.
  • You have connected the cluster with the kubectl command line tool or CloudShell.
  • The pressure testing tool Apache Benchmark has been installed.
Creating a Workload and a Service for the Workload
This section provides an example of how to route external traffic for two Services using Nginx ingresses.
  1. Create a test-app workload and a Service for it.
    1. Write a test-app.yaml file.
      apiVersion: apps/v1
      kind: Deployment
        labels:
          app: test-app
        replicas: 1
        selector:
          matchLabels:
            app: test-app
        template:
            labels:
              app: test-app
            containers:
            - image: skto/sample-app:v2
              ports:
              - name: http
                containerPort: 8080
      apiVersion: v1
      kind: Service
        namespace: default
        labels:
          app: test-app
        ports:
          - port: 8080
            protocol: TCP
            targetPort: 8080
        selector:
          app: test-app
        type: ClusterIP
    2. Deploy the test-app workload and the corresponding Service.
      kubectl apply -f test-app.yaml
  2. Create a sample-app workload and a Service for it.
    1. Write a sample-app.yaml file.
      apiVersion: apps/v1
      kind: Deployment
        labels:
          app: sample-app
        replicas: 1
        selector:
          matchLabels:
            app: sample-app
        template:
            labels:
              app: sample-app
            containers:
              ports:
              - name: http
                containerPort: 8080
      apiVersion: v1
      kind: Service
        namespace: default
        labels:
          app: sample-app
        ports:
          - port: 80
            protocol: TCP
            targetPort: 8080
        selector:
          app: sample-app
        type: ClusterIP
    2. Deploy the sample-app workload and the corresponding Service.
      kubectl apply -f sample-app.yaml
  3. Deploy an ingress.
    1. Write an ingress.yaml file.
      kind: Ingress
        namespace: default
        ingressClassName: nginx
        rules:
          - host: test.example.com
            http:
              paths:
                - backend:
                    service:
                      port:
                        number: 80
                  path: /
                - backend:
                    service:
                      port:
                        number: 8080
                  path: /home
      • host: specifies the Service access domain name. In this example, test.example.com is used.
      • path: specifies the URL to be accessed. After receiving a request, the system matches the request with the corresponding Service based on the routing rules and accesses the corresponding pod through the Service.
      • backend: consists of the Service name and Service port and specifies the Service forwarded by the current path.
    2. Deploy an ingress.
      kubectl apply -f ingress.yaml
    3. Obtain an ingress.
      kubectl get ingress -o wide
    4. After the deployment is successful, log in to the target node and add the service domain name and the IP address of the load balancer associated with NGINX Ingress Controller to the local hosts file of the node. The IP address of the load balancer associated with NGINX Ingress Controller is that obtained in 3.c.
      export NGINXELB=xx.xx.xx.xx
      echo -n "${NGINXELB}  test.example.com" >> /etc/hosts
    5. Log in to the cluster node and access the host address through the / and /home paths.
      NGINX Ingress Controller accesses sample-app and test-app based on the preceding configurations.
      # curl test.example.com/
      Hello from '/' path!
      # curl test.example.com/home
      Hello from '/home' path!
Modifying user-adapter-config in Prometheus
  1. Run the following command to edit user-adapter-config:
    kubectl -n monitoring edit configmap user-adapter-config
  2. Add the following rules to the ConfigMap of the adapter:
    apiVersion: v1
    data:
      config.yaml: |
        rules:
        - metricsQuery: sum(rate(<<.Series>>{<<.LabelMatchers>>}[2m])) by (<<.GroupBy>>)
          name:
            as: ${1}_per_second
            matches: ^(.*)_requests
          resources:
            namespaced: false
            overrides:
              exported_namespace:
                resource: namespace
              service:
                resource: service
          seriesQuery: nginx_ingress_controller_requests
        resourceRules:
          cpu:
            containerQuery: sum(rate(container_cpu_usage_seconds_total{<<.LabelMatchers>>,container!="",pod!=""}[1m])) by (<<.GroupBy>>)
            nodeQuery: sum(rate(container_cpu_usage_seconds_total{<<.LabelMatchers>>, id='/'}[1m])) by (<<.GroupBy>>)
            resources:
              overrides:
                instance:
                  resource: node
                namespace:
                  resource: namespace
                pod:
                  resource: pod
            containerLabel: container
          memory:
            containerQuery: sum(container_memory_working_set_bytes{<<.LabelMatchers>>,container!="",pod!=""}) by (<<.GroupBy>>)
            nodeQuery: sum(container_memory_working_set_bytes{<<.LabelMatchers>>,id='/'}) by (<<.GroupBy>>)
            resources:
              overrides:
                instance:
                  resource: node
                namespace:
                  resource: namespace
                pod:
                  resource: pod
  3. Restart custom-metrics-apiserver.
    kubectl -n monitoring delete pod -l app=custom-metrics-apiserver
  4. Log in to the cluster node and access the host address through the / and /home paths for multiple times.
  5. Run the following command to check whether the metric is added:
    kubectl get --raw /apis/custom.metrics.k8s.io/v1beta1/namespaces/default/services/*/nginx_ingress_controller_per_second | python -m json.tool
Creating an HPA Policy
  1. Create an hpa.yaml file and configure auto scaling for the test-app and sample-app workloads based on Prometheus metrics.
    apiVersion: autoscaling/v2
    kind: HorizontalPodAutoscaler
      name: sample-hpa  # HPA name
      scaleTargetRef:
        apiVersion: apps/v1
        kind: Deployment
        name: sample-app  # Deployment name
      minReplicas: 1      # Minimum number of pods
      maxReplicas: 10     # Maximum number of pods
      metrics:
        - type: Object
          object:
            metric:
              name: nginx_ingress_controller_per_second  # Metric
            describedObject:
              apiVersion: v1
              kind: service
              name: sample-app  # Service of the Deployment
            target:
              type: Value
              value: 30   # Scaling is triggered when the metric value is within the range of (Actual value/30)±0.1.
      scaleTargetRef:
        apiVersion: apps/v1
        kind: Deployment
      minReplicas: 1
      maxReplicas: 10
      metrics:
        - type: Object
          object:
            metric:
            describedObject:
              apiVersion: v1
              kind: service
            target:
              type: Value
              value: 30
  2. Deploy the HPA policy.
    kubectl apply -f hpa.yaml
  3. Check the HPA deployment.
    kubectl get hpa
Verifying Scaling
  1. Log in to the target cluster node and perform a pressure testing on the /home path.
    ab -c 50 -n 5000 test.example.com/home
  2. Check the HPA.
    kubectl get hpa
  3. Log in to the target cluster node and perform a pressure testing on the root path.
  4. Check the HPA.
    kubectl get hpa
    Compared with the HPA metrics obtained before the pressure testing, the service application is scaled out when the number of requests exceeds the threshold.
