Help Center/Cloud Container Engine/Best Practices/DevOps/Continuous Delivery Using Argo CD
Updated on 2026-03-10 GMT+08:00
Background
ArgoCD is a declarative, GitOps continuous delivery tool for Kubernetes. ArgoCD leverages Git as its foundation and supports the declarative configuration of various Kubernetes objects. It enables rapid application deployment in Kubernetes clusters, with efficient version-based tracking and multi-cluster deployment. This approach allows the same application to be consistently deployed across multiple clusters.
Figure 1 Argo CD workflow
This section describes how to interconnect ArgoCD with CCE to perform continuous deployment.
Preparations
  1. Create a CCE cluster and a node and bind an EIP to the node for downloading an image during Argo CD installation.
  2. Create an ECS, bind an EIP to the ECS, and download and configure kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  3. Prepare an application in the Git repository. This section uses the Nginx sample application in the https://gitlab.com/c8147/examples.git repository.
Installing Argo CD
  1. Install the Argo CD server in the cluster. The Argo CD server v2.4.0 is used as an example.
    kubectl create namespace argocd
    kubectl apply -n argocd -f https://raw.githubusercontent.com/argoproj/argo-cd/v2.4.0/manifests/install.yaml
    Check whether the installation is successful. If all pods in the argocd namespace are in the Running status, the installation is successful.
    kubectl get pod -A
    Information similar to the following is displayed:
    NAMESPACE     NAME                                                READY   STATUS    RESTARTS   AGE
    argocd        argocd-application-controller-0                     1/1     Running   0          8m32s
    argocd        argocd-applicationset-controller-789457b498-6n6l5   1/1     Running   0          8m32s
    argocd        argocd-dex-server-748bddb496-bxj2c                  1/1     Running   0          8m32s
    argocd        argocd-notifications-controller-8668ffdd75-q7wdb    1/1     Running   0          8m32s
    argocd        argocd-redis-55d64cd8bf-g85np                       1/1     Running   0          8m32s
    argocd        argocd-repo-server-778d695657-skprm                 1/1     Running   0          8m32s
    argocd        argocd-server-59c9ccff4c-vd9ww                      1/1     Running   0          8m32s
  2. Change the Service type of argocd-server to NodePort.
    kubectl patch svc argocd-server -n argocd -p '{"spec": {"type": "NodePort"}}'
    service/argocd-server patched
    View the modification result.
    kubectl -n argocd get svc
    NAME                                      TYPE        CLUSTER-IP       EXTERNAL-IP   PORT(S)                      AGE
    argocd-applicationset-controller          ClusterIP   10.247.237.53    <none>        7000/TCP,8080/TCP            18m
    argocd-dex-server                         ClusterIP   10.247.164.111   <none>        5556/TCP,5557/TCP,5558/TCP   18m
    argocd-metrics                            ClusterIP   10.247.138.98    <none>        8082/TCP                     18m
    argocd-notifications-controller-metrics   ClusterIP   10.247.239.85    <none>        9001/TCP                     18m
    argocd-redis                              ClusterIP   10.247.220.90    <none>        6379/TCP                     18m
    argocd-repo-server                        ClusterIP   10.247.1.142     <none>        8081/TCP,8084/TCP            18m
    argocd-server                             NodePort    10.247.57.16     <none>        80:30118/TCP,443:31221/TCP   18m
    argocd-server-metrics                     ClusterIP   10.247.206.190   <none>        8083/TCP                     18m
  3. To access Argo CD using the argocd-server Service, use <node-IP-address>:<port-number>. In this example, the port number is 31221.
    The login username is admin, and the password can be obtained by running the following command:
    kubectl -n argocd get secret argocd-initial-admin-secret -o jsonpath="{.data.password}" | base64 -d;echo
  4. Install the Argo CD client on the ECS. The Argo CD client v2.4.0 is used as an example.
    wget https://github.com/argoproj/argo-cd/releases/download/v2.4.0/argocd-linux-amd64
    cp argocd-linux-amd64 /usr/local/bin/argocd
    chmod +x /usr/local/bin/argocd
    Run the following command:
    argocd version
    If information similar to the following is displayed, it indicates that the client has been installed.
    argocd: v2.4.0+91aefab
      BuildDate: 2022-06-10T17:44:14Z
      GitCommit: 91aefabc5b213a258ddcfe04b8e69bb4a2dd2566
      GitTreeState: clean
      GoVersion: go1.18.3
      Compiler: gc
      Platform: linux/amd64
    FATA[0000] Argo CD server address unspecified
Deploying an Application Using Argo CD
  1. Add a CCE cluster to Argo CD.
    1. Log in to an ECS.
    2. Check the kubectl context configuration.
      kubectl config get-contexts
      CURRENT   NAME       CLUSTER           AUTHINFO   NAMESPACE
      *         internal   internalCluster   user
    3. Log in to the Argo CD server. The username is admin. You can obtain the server IP address and password from 1. If the ECS and the cluster are in the same VPC, the node IP address can be a private IP address.
      argocd login <Node IP address:Port number> --username admin --password <password>
      WARNING: server certificate had error: x509: cannot validate certificate for 192.168.0.52 because it doesn't contain any IP SANs. Proceed insecurely (y/n)? y
      'admin:login' logged in successfully
      Context '192.168.0.52:31221' updated
    4. Add a CCE cluster.
      argocd cluster add internal --kubeconfig /root/.kube/config --name argocd-01
      In the preceding command, internal is the context name queried in 1.b, /root/.kube/config is the path of the kubectl configuration file, and argocd-01 is the cluster name defined in Argo CD.
      WARNING: This will create a service account `argocd-manager` on the cluster referenced by context `internal` with full cluster level privileges. Do you want to continue [y/N]? y
      INFO[0002] ServiceAccount "argocd-manager" already exists in namespace "kube-system"
      INFO[0002] ClusterRole "argocd-manager-role" updated
      INFO[0002] ClusterRoleBinding "argocd-manager-role-binding" updated
      Cluster "https://192.168.0.113:5443"" added
      Log in to the Argo CD page. You can see that the connection is successful.
  2. Connect to the Git repository.
    argocd repo add https://gitlab.com/c8147/examples.git --username <username>  --password <password>
    In the preceding command, https://gitlab.com/c8147/examples.git indicates the repository address, and <username> and <password> indicate the repository login username and password. Replace them with the actual values.
    Repository 'https://gitlab.com/c8147/cidemo.git' added
    Log in to the Argo CD page. You can see that the cluster has been added.
  3. Add an application to Argo CD.
    argocd app create nginx --repo https://gitlab.com/c8147/examples.git  --path nginx --dest-server https://192.168.0.113:5443 --dest-namespace default
    https://gitlab.com/c8147/examples.git indicates the repository address, nginx indicates the repository path, https://192.168.0.113:5443 indicates the address of the cluster to be deployed, and default indicates the namespace.
    In this example, the nginx directory in the GitLab repository contains a YAML file of the Nginx application. The file includes a Deployment and a Service.
    After the application is created, you can view its details.
    argocd app list
    NAME   CLUSTER                     NAMESPACE  PROJECT  STATUS     HEALTH   SYNCPOLICY  CONDITIONS  REPO                                   PATH   TARGET
    nginx  https://192.168.0.113:5443  default    default  OutOfSync  Missing  <none>      <none>      https://gitlab.com/c8147/examples.git  nginx
    Log in to the Argo CD page. You can see that the application has been added.
  4. Synchronize the application and deploy the application to the specified cluster.
    argocd app sync nginx
    TIMESTAMP                  GROUP        KIND   NAMESPACE                  NAME    STATUS    HEALTH        HOOK  MESSAGE
    2022-10-24T12:15:10+08:00            Service     default                 nginx  OutOfSync  Missing
    2022-10-24T12:15:10+08:00   apps  Deployment     default                 nginx  OutOfSync  Missing
    2022-10-24T12:15:10+08:00            Service     default                 nginx    Synced  Healthy
    2022-10-24T12:15:10+08:00            Service     default                 nginx    Synced   Healthy              service/nginx created
    2022-10-24T12:15:10+08:00   apps  Deployment     default                 nginx  OutOfSync  Missing              deployment.apps/nginx created
    2022-10-24T12:15:10+08:00   apps  Deployment     default                 nginx    Synced  Progressing              deployment.apps/nginx created
    Project:            default
    Server:             https://192.168.0.113:5443
    Namespace:          default
    URL:                https://192.168.0.178:32459/applications/nginx
    Repo:               https://gitlab.com/c8147/examples.git
    Target:
    Path:               nginx
    SyncWindow:         Sync Allowed
    Sync Policy:        <none>
    Sync Status:        Synced to  (dd15906)
    Health Status:      Progressing
    Operation:          Sync
    Sync Revision:      dd1590679856bd9288036847bdc4a5556c169267
    Phase:              Succeeded
    Start:              2022-10-24 12:15:10 +0800 CST
    Finished:           2022-10-24 12:15:10 +0800 CST
    Duration:           0s
    Message:            successfully synced (all tasks run)
  5. You can see that an Nginx workload and a Service have been deployed in the CCE cluster.
    1. View the workload.
      kubectl get deployment
      NAME    READY   UP-TO-DATE   AVAILABLE   AGE
      nginx   1/1     1            1           2m47s
    2. View the Service.
      kubectl get svc
      kubernetes   ClusterIP   10.247.0.1      <none>        443/TCP   5h12m
      nginx        ClusterIP   10.247.177.24   <none>        80/TCP    2m52s
  6. Log in to the Argo CD page. You can see that the application status has changed to Synced.
Using Argo Rollouts for Grayscale Release
Argo Rollouts is a Kubernetes controller that provides advanced deployment capabilities such as blue-green, grayscale (canary) release, and progressive delivery.
  1. Install the argo-rollouts server in the cluster. The argo-rollouts server v1.2.2 is used as an example.
    kubectl create namespace argo-rollouts
    kubectl apply -f https://github.com/argoproj/argo-rollouts/releases/download/v1.2.2/install.yaml -n argo-rollouts
    If the application is deployed in multiple clusters, install the argo-rollouts server in each target cluster.
  2. Install kubectl of argo-rollouts on the ECS. The argo-rollouts server v1.2.2 is used as an example.
    curl -LO https://github.com/argoproj/argo-rollouts/releases/download/v1.2.2/kubectl-argo-rollouts-linux-amd64
    chmod +x ./kubectl-argo-rollouts-linux-amd64
    sudo mv ./kubectl-argo-rollouts-linux-amd64 /usr/local/bin/kubectl-argo-rollouts
    Run the following commands to check whether the add-on has been installed:
    kubectl argo rollouts version
    kubectl-argo-rollouts: v1.2.2+22aff27
      BuildDate: 2022-07-26T17:24:43Z
      GitCommit: 22aff273bf95646e0cd02555fbe7d2da0f903316
      GitTreeState: clean
      GoVersion: go1.17.6
      Compiler: gc
  3. Prepare two sample Nginx application images whose versions are v1 and v2, respectively. The welcome pages are displayed as "nginx:v1!" and "nginx:v2!", respectively.
    Create a Dockerfile. The content of the Dockerfile for v1 is as follows: (For v2, replace nginx:v1! with nginx:v2!.)
    FROM nginx:latest
    RUN echo '<h1>nginx:v1!</h1>' > /usr/share/nginx/html/index.html
    Create a v1 image.
    docker build -t nginx:v1 .
    Log in to SWR and push the image to SWR. For details, see Pushing an Image. During the push, container indicates the organization name in SWR. Configure it as required.
    docker login -u {region}@xxx -p xxx swr.{region}.myhuaweicloud.com
    docker tag nginx:v1 swr.cn-east-3.myhuaweicloud.com/container/nginx:v1
    docker push swr.cn-east-3.myhuaweicloud.com/container/nginx:v1
    Create a v2 image and push it to SWR in the same way.
  4. Deploy an Argo Rollouts controller. In this example, the controller first shifts 20% of all service traffic to the new version. Then, manually increase the traffic proportion. After that, the controller automatically and gradually increases traffic until the release is complete.
    Create a file named rollout-canary.yaml:
    apiVersion: argoproj.io/v1alpha1
    kind: Rollout
      name: rollout-canary  # Custom Rollout name
      replicas: 5  # Five replicas
      strategy:  # Upgrade policy
        canary:   # Grayscale (canary) release
          steps:  # Release pace (duration can be set for each phase)
          - setWeight: 20 # Traffic weight
          - pause: {}  # If this field is not specified, the release is paused.
          - setWeight: 40
          - pause: {duration: 10}  # Pause duration, in seconds.
          - setWeight: 60
          - setWeight: 80
      revisionHistoryLimit: 2
      selector:
        matchLabels:
          app: rollout-canary
      template:
          labels:
            app: rollout-canary
          containers:
          - name: rollout-canary
            image: swr.cn-east-3.myhuaweicloud.com/container/nginx:v1  # The pushed image, whose version is v1.
            ports:
            - name: http
              containerPort: 80
              protocol: TCP
            resources:
              requests:
                memory: 32Mi
                cpu: 5m
          imagePullSecrets:
            - name: default-secret
    apiVersion: v1
    kind: Service
      type: NodePort
      ports:
      - port: 80
        targetPort: 80
        nodePort: 31270  # The custom node port number
      selector:
        app: rollout-canary
    Run the following command to create the preceding two resource objects:
    kubectl apply -f rollout-canary.yaml
    The Argo Rollouts controller does not trigger upgrade during initial creation and the configured release policy does not take effect. Only the number of replicas increases to 100% immediately.
  5. Argo Rollouts visualizes the rollout process and related resource objects to display real-time changes. You can run the get rollout --watch command to observe the deployment process, for example:
    kubectl argo rollouts get rollout rollout-canary --watch
    In the preceding command, rollout-canary indicates the custom Rollout name.
  6. After the creation is complete, you can access the Nginx application using Node EIP:Port number. The port number is specified in the Service resource in the rollout-canary.yaml file. In this example, the port number is 31270.
  7. Use the v2 image to update the application.
    kubectl argo rollouts set image rollout-canary rollout-canary=swr.cn-east-3.myhuaweicloud.com/container/nginx:v2
    The controller will update the application according to the update policy. In this example, a 20% traffic weight is set in the first step, and the release is paused until the user cancels or continues. You can run the following command to view the detailed process. The release is paused.
    You can view that only one of the five replicas runs the new version, that is, the weight of 20% defined in setWeight: 20.
    If you run the following command multiple times, 20% of the responses are from v2.
    for i in {1..10}; do curl <Node EIP:Port number>; done;
    Verification result:
    <h1>nginx:v2!</h1>
    <h1>nginx:v1!</h1>
    <h1>nginx:v1!</h1>
    <h1>nginx:v1!</h1>
    <h1>nginx:v1!</h1>
    <h1>nginx:v1!</h1>
    <h1>nginx:v1!</h1>
    <h1>nginx:v1!</h1>
    <h1>nginx:v2!</h1>
    <h1>nginx:v1!</h1>
  8. Manually update the version.
    kubectl argo rollouts promote rollout-canary
    In this example, the remaining steps are fully automated until the release is complete. Run the following command to view the detailed process. The controller gradually switches all traffic to the new version.
  9. You can run the following command to use more Argo Rollouts functions, such as terminating or rolling back a release:
    kubectl argo rollouts --help
