Migrating Images to SWR Using image-migrator
To ensure that container images can be properly pulled after cluster migration and improve container deployment efficiency, you are advised to migrate self-built image registries to Huawei Cloud SoftWare Repository for Container (SWR).
image-migrator is an image migration tool that can automatically migrate images from a Docker registry built on Docker Registry v2 to SWR.
Preparations
Before the migration, prepare a server with kubectl installed for the connection between the source and destination clusters. The server must have at least 5 GB of local disk space and at least 8 GB of memory so that image-migrator can work properly and can store related data, such as data collected from the source cluster and recommendation data of the destination cluster.
image-migrator can run on Linux (x86 and Arm) and Windows.
Before using image-migrator in Linux, run the chmod u+x Tool name command (for example, chmod u+x image-migrator-linux-amd64) to grant the execute permission.
image-migrator |
image-migrator is an image migration tool that can automatically migrate images from a Docker registry built on Docker Registry v2 to SWR, or from a registry on a third-party cloud to SWR. |
Linux x86: https://ucs-migration.obs.cn-north-4.myhuaweicloud.com/toolkits/image-migrator-linux-amd64 Linux Arm: https://ucs-migration.obs.cn-north-4.myhuaweicloud.com/toolkits/image-migrator-linux-arm64 Windows: https://ucs-migration.obs.cn-north-4.myhuaweicloud.com/toolkits/image-migrator-windows-amd64.exe |
How image-migrator Works
When using image-migrator to migrate images to SWR, you need to prepare two files. One is the registry access permission file auth.json. The two objects in the file are the accounts and passwords of the source and destination registries. The other is the image list file images.json, which consists of multiple image synchronization rules. Each rule contains a source repository (key) and a destination repository (value). Place these two files in the directory where image-migrator is located and run a simple command to migrate the image. The two files are described as follows:
- auth.json
auth.json is the registry access permission file. Each object is the username and password of a registry. Generally, you must have permission to pull images from and access image tags in the source registry and permission to push images to and create repositories in the destination registry. If you access a registry anonymously, you do not need to enter the username and password. Structure of the auth.json file:
{ "Source registry address": { }, "Destination registry address": { "username": "xxxxxx", "password": "xxxxxx", "insecure": true } }To be more specific:
- The Source registry address and Destination registry address can be in the registry or registry/namespace format matching that in images.json. The matched URL in images.json uses the corresponding username and password for image synchronization. The registry/namespace format is preferred.
If the destination registry address is in the registry format, you can obtain it from the SWR console. On the Dashboard page, click Generate Login Command in the upper right corner. The domain name at the end of the login command is the SWR registry address, for example, swr.cn-north-4.myhuaweicloud.com. Note that the address varies depending on the region. Switch to the corresponding region to obtain the address. If the value is in the registry/namespace format, replace namespace with the organization name of SWR.
- username: (Optional) username. You can set it to a specific value or use a string of the ${env} or $env type to reference an environment variable.
- password: (Optional) password. You can set it to a specific value or use a string of the ${env} or $env type to reference an environment variable.
- insecure: (Optional) whether registry is an HTTP service. If yes, the value of insecure is true. The default value is false.
The username of the destination SWR registry is in the following format: Regional project name@AK. The password is the encrypted login key based on the AK and SK. For details, see Obtaining a Long-Term Login Command.
Example:
{ "quay.io/coreos": { }, "swr.cn-north-4.myhuaweicloud.com": { "username": "cn-north-4@RVHVMX******", "password": "cab4ceab4a1545***************", "insecure": true } } - The Source registry address and Destination registry address can be in the registry or registry/namespace format matching that in images.json. The matched URL in images.json uses the corresponding username and password for image synchronization. The registry/namespace format is preferred.
- images.json
This file is essentially a list of images to migrate and consists of multiple image synchronization rules. Each rule contains a source repository (key) and a destination repository (value). The specific requirements are as follows:
- The largest unit that can be synchronized using one rule is a repository. An entire namespace or registry cannot be synchronized using one rule.
- The formats of the source and destination repositories are similar to those of the image URL used by the docker pull or docker push command (registry/namespace/repository:tag).
- Both the source and destination repositories (if the destination repository is not an empty string) contain at least registry/namespace/repository.
- The source repository cannot be empty. To synchronize data from one source repository to multiple destination repositories, you need to configure multiple rules.
- The destination repository name can be different from the source repository name. In this case, the synchronization function is similar to docker pull + docker tag + docker push.
- If the source repository field does not contain any tag, all tags of the repository will be synchronized to the destination repository. In this case, the destination repository field cannot contain a tag.
- If the source repository field contains a tag, only that tag in the source repository will be synchronized to the destination repository. If the destination repository does not contain a tag, the source tag will be used at the destination by default.
- If the destination repository is an empty string, the source image will be synchronized to the default namespace of the default registry. The repository and tag are the same as those of the source repository. The default registry and namespace can be configured using command line parameters and environment variables.
Example:
{ "quay.io/coreos/etcd:1.0.0": "swr.cn-north-4.myhuaweicloud.com/test/etcd:1.0.0", "quay.io/coreos/etcd": "swr.cn-north-4.myhuaweicloud.com/test/etcd", "quay.io/coreos/etcd:2.7.3": "swr.cn-north-4.myhuaweicloud.com/test/etcd" }We provide config, a subcommand of image-migrator, to automatically obtain the images that are being used by workloads in a cluster. For details, see Usage of image-migrator config. After obtaining the images.json file, you can modify, add, or delete its content as needed.
How to Use image-migrator
image-migrator can run on Linux (x86 and Arm) and Windows. The usage is similar in both environments. This section uses the Linux (x86) environment as an example.
If Linux (Arm) or Windows is used, replace image-migrator-linux-amd64 in the following command with image-migrator-linux-arm64 or image-migrator-windows-amd64.exe.
Run ./image-migrator-linux-amd64 -h in the directory where image-migrator is located to learn about its usage.
- --auth: specifies the path of auth.json. By default, auth.json is stored in the directory where image-migrator is located.
- --images: specifies the path of images.json. By default, images.json is stored in the directory where image-migrator is located.
- --log: specifies the path for storing logs generated by image-migrator. The default value is image-migrator.log in the current directory of image-migrator.
- --namespace: specifies the default namespace of the destination repository. That is, if the namespace of the destination repository is not specified in images.json, you can specify it when running the migration command.
- --registry: specifies the default registry of the destination repository. That is, if the registry of the destination repository is not specified in images.json, you can specify it when running the migration command.
- --retries: specifies the number of retries allowed when the migration fails. The default value is 3.
- --workers: specifies the number of concurrent workers for image migration. The default value is 7.
$ ./image-migrator-linux-amd64 -h
A Fast and Flexible docker registry image images tool implement by Go.
Usage:
image-migrator [flags]
Aliases:
image-migrator, image-migrator
Flags:
--auth string auth file path. This flag need to be pair used with --images. (default "./auth.json")
-h, --help help for image-migrator
--images string images file path. This flag need to be pair used with --auth (default "./images.json")
--log string log file path (default "./image-migrator.log")
--namespace string default target namespace when target namespace is not given in the images config file, can also be set with DEFAULT_NAMESPACE environment value
--registry string default target registry url when target registry is not given in the images config file, can also be set with DEFAULT_REGISTRY environment value
-r, --retries int times to retry failed tasks (default 3)
-w, --workers int numbers of working goroutines (default 7)
$./image-migrator --workers=5 --auth=./auth.json --images=./images.json --namespace=test \
--registry=swr.cn-north-4.myhuaweicloud.com --retries=2
$ ./image-migrator
Start to generate images tasks, please wait ...
Start to handle images tasks, please wait ...
Images(38) migration finished, 0 images tasks failed, 0 tasks generate failed
Example:
./image-migrator --workers=5 --auth=./auth.json --images=./images.json --namespace=test --registry=swr.cn-north-4.myhuaweicloud.com --retries=2
The preceding command is used to migrate images in the images.json file to swr.cn-north-4.myhuaweicloud.com/test. If the migration fails, you can retry twice. A maximum of five images can be migrated at a time.
The config subcommand of image-migrator can be used to obtain images used in cluster applications and generate the images.json file in the directory where image-migrator is located. You can run ./image-migrator-linux-amd64 config -h to learn how to use the config subcommand.
- -k, --kubeconfig: specifies the location of kubeconfig files of kubectl. The default value is $HOME/.kube/config. A kubeconfig file is used to configure access to a Kubernetes cluster. The file contains the authentication credential and endpoint (address) required for accessing a Kubernetes cluster. For details, see the Kubernetes documentation.
- -n, --namespaces: specifies the namespace of the image to be obtained. Multiple namespaces are separated by commas (,), for example, ns1,ns2,ns3. The default value is "", indicating that images of all namespaces are obtained.
- -t, --repo: specifies the destination registry address (registry/namespace).
$ ./image-migrator-linux-amd64 config -h
generate images.json
Usage:
image-migrator config [flags]
Flags:
-h, --help help for config
-k, --kubeconfig string The kubeconfig of k8s cluster's. Default is the $HOME/.kube/config. (default "/root/.kube/config")
-n, --namespaces string Specify a namespace for information collection. If multiple namespaces are specified, separate them with commas (,), such as ns1,ns2. default("") is all namespaces
-t, --repo string target repo,such as swr.cn-north-4.myhuaweicloud.com/test
Examples:
- Specify one namespace:
./image-migrator-linux-amd64 config -n default -t swr.cn-north-4.myhuaweicloud.com/test
- Specify multiple namespaces:
./image-migrator-linux-amd64 config -n default,kube-system -t swr.cn-north-4.myhuaweicloud.com/test
- If no namespace is specified, images of all namespaces are obtained:
./image-migrator-linux-amd64 config -t swr.cn-north-4.myhuaweicloud.com/test
- Prepare a registry access permission file auth.json.
Create an auth.json file and modify it based on the required format. If a registry is accessed anonymously, you do not need to enter information such as the username and password. Place the file in the directory where image-migrator is located.
Example:
{ "quay.io/coreos": { }, "swr.cn-north-4.myhuaweicloud.com": { "username": "cn-north-4@RVHVMX******", "password": "cab4ceab4a1545***************", "insecure": true } }For details about the parameters, see the auth.json.
- Prepare an image list file images.json.
- Connect to the source cluster using kubectl. For details, see Connecting to a Cluster Using kubectl.
- Run the config subcommand of image-migrator to generate an images.json file.
You can refer to the methods and examples in Usage of image-migrator config to obtain the images used in the source cluster applications without specifying a namespace, or by specifying one or multiple namespaces.
- Modify the images.json file to make it meet the requirements in images.json.
- Migrate images.
You can run the default ./image-migrator-linux-amd64 command to migrate images or configure image-migrator parameters as needed.
For example, run the following command:
./image-migrator-linux-amd64 --workers=5 --auth=./auth.json --images=./images.json --namespace=test --registry=swr.cn-north-4.myhuaweicloud.com --retries=2
Example:
$ ./image-migrator-linux-amd64 Start to generate images tasks, please wait ... Start to handle images tasks, please wait ... Images(38) migration finished, 0 images tasks failed, 0 tasks generate failed
- View the results.
After the preceding command is executed, information similar to the following is displayed:
The preceding information indicates that 38 images have been migrated to SWR.
