Updated on 2026-05-21 GMT+08:00
Migrating Images to SWR Using Docker Commands
SWR provides easy-to-use image hosting and efficient distribution services. If a small quantity of images need to be migrated, enterprises can use the docker pull/push command to migrate images to SWR.
  1. Pull images from the source repository.
    Run the docker pull command to pull the images.
    Example: docker pull nginx:latest
    Run the docker images command to check whether the images are successfully pulled.
    # docker images
    REPOSITORY                        TAG       IMAGE ID       CREATED         SIZE
    nginx                             latest    22f2bf2e2b4f   5 hours ago     22.8MB
  2. Push the images pulled in 1 to SWR.
    1. Log in to the VM where the destination container is located and log in to SWR. For details, see Uploading an Image Through a Container Engine Client.
    2. Tag the images.
      docker tag [Image name:Tag name] [Image repository address]/[Organization name]/[Image name:Tag name]
      Example:
      docker tag nginx:v1 swr.ap-southeast-1.myhuaweicloud.com/cloud-develop/nginx:v1
    3. Run the following command to push the images to the destination image repository.
      docker push [image-repository-address]/[organization-name]/[image-name:tag-name]
      Example:
      docker push swr.ap-southeast-1.myhuaweicloud.com/cloud-develop/nginx:v1
    4. Check whether the following information is returned. If yes, the push is successful.
      fbce26647e70: Pushed
      fb04ab8effa8: Pushed
      8f736d52032f: Pushed
      009f1d338b57: Pushed
      678bbd796838: Pushed
      d1279c519351: Pushed
      f68ef921efae: Pushed
      v1: digest: sha256:0cdfc7910db531bfa7726de4c19ec556bc9190aad9bd3de93787e8bce3385f8d size: 1780
      To view the pushed image, refresh the My Images page.
