Locating Container Faults Using a Core Dump
Application Scenarios
A core dump is when the Linux OS saves the memory status to a file after a program crashes or stops unexpectedly. You can analyze the file to locate the fault.
Generally, when a service application crashes, its container exits and is reclaimed and destroyed. Therefore, container core files need to be permanently stored on the node or cloud storage. This section describes how to configure a container core dump.
Notes and Constraints
When a container core dump is persistently stored in OBS (parallel file system or object bucket), the default mount option umask=0 is used. As a result, although the core dump file is generated, its information cannot be written to the core file. You can configure the OBS mount option umask=0077 to store the core dump to OBS. For details, see Configuring OBS Mount Options.
Enabling a Node Core Dump
Log in to the node, run the following command to enable a core dump, and configure the path and format for storing core files:
echo "/tmp/cores/core.%h.%e.%p.%t" > /proc/sys/kernel/core_pattern
%h, %e, %p, and %t are placeholders, which are described as follows:
- %h: hostname (or pod name). You are advised to configure this parameter.
- %e: program file name. You are advised to configure this parameter.
- %p: (Optional) process ID
- %t: (Optional) time of the core dump
After the core dump is enabled by running the command, the generated core file is named in the format of core.{Host name}.{Program file name}.{Process ID}.{Time}.
You can also configure a pre-installation or post-installation script to automatically run this command when creating a node.
EulerOS 2.3 Systemd has a bug that affects container core dumps. To use core dumps, perform the following operations:
- In the /usr/lib/systemd/system/docker.service file on a node, change the value of LimitCORE to infinity.
- Restart Docker.
- Redeploy service containers.
Permanently Storing a Core Dump
apiVersion: v1
kind: Pod
volumes:
- name: coredump-path
hostPath:
path: /home/coredump
containers:
- name: ubuntu
image: ubuntu:12.04
command: ["/bin/sleep","3600"]
volumeMounts:
- mountPath: /tmp/cores
name: coredump-path Create the pod.
kubectl create -f pod.yaml
Verification
- Obtain the pod name:
kubectl get pod
Information similar to the following is displayed:
NAME READY STATUS RESTARTS AGE coredump 1/1 Running 0 56s
- Access the container:
kubectl exec -it coredump -- /bin/shTrigger a segmentation fault of the current shell terminal.
kill -s SIGSEGV $$
command terminated with exit code 139
- Log in to the node and check whether the core file has been generated in /home/coredump.
ls /home/coredump
If information similar to the following is displayed, the core file has been generated.
core.coredump.bash.18.1650438992
