Using Secrets Securely in a CCE Cluster
CCE now provides static encryption for secrets. Secrets created by users are encrypted and stored in the clusters' etcd. Currently, Secrets are mainly used as environment variables or through file mounts. Regardless of which method is used, CCE always delivers the data exactly as you originally configured it. Therefore, it is advised to:
- Avoid logging any sensitive information.
- Configure stricter permissions if secrets are used through file mounts and the default file permission inside the container is 0644. An example is as follows:
apiversion: v1 kind: Pod metadata: name: mypod spec: containers: - name: mypod image: redis volumeMounts: - name: foo mountPath: "/etc/foo" volumes: - name: foo secret: secretName: mysecret defaultMode: 256In defaultMode: 256, 256 is a decimal number, which corresponds to the octal number 0400.
- Hide secrets in containers by customizing the file names when mounting them as files.
apiVersion: v1 kind: Secret metadata: name: dotfile-secret data: .secret-file: dmFsdWUtMg0KDQo= --- apiVersion: v1 kind: Pod metadata: name: secret-dotfiles-pod spec: volumes: - name: secret-volume secret: secretName: dotfile-secret containers: - name: dotfile-test-container image: k8s.gcr.io/busybox command: - ls - "-1" - "/etc/secret-volume" volumeMounts: - name: secret-volume readOnly: true mountPath: "/etc/secret-volume"In this way, .secret-file cannot be seen by running ls -l in the /etc/secret-volume/ directory, but can be viewed by running ls -al.
- Encrypt sensitive data by yourself before creating secrets and decrypt them only when needed.
Using a Bound Service Account Token to Access a Cluster
Service account tokens based on secrets do not support expiration settings or automatic updates. Because they are stored in secrets, the tokens remain in the secrets even after the pods are deleted. This can pose a security risk if the tokens are leaked. For CCE clusters v1.23 or later, it is advised to use bound service account tokens. They support token expiration settings and align the tokens' lifecycle with the pods, reducing the risk of credential leakage. An example is as follows:
apiVersion: apps/v1
kind: Deployment
namespace: security-example
replicas: 1
selector:
matchLabels:
app: security-token-example
label: security-token-example
template:
annotations:
seccomp.security.alpha.kubernetes.io/pod: runtime/default
labels:
serviceAccountName: test-sa
containers:
- image: ...
imagePullPolicy: Always
volumes:
- name: test-projected
projected:
defaultMode: 420
sources:
- serviceAccountToken:
expirationSeconds: 1800
path: token
- configMap:
items:
- key: ca.crt
path: ca.crt
- downwardAPI:
items:
- fieldRef:
apiVersion: v1
fieldPath: metadata.namespace
path: namespace For details, see Managing Service Accounts.
Using the CCE Secrets Manager for DEW Add-on
The CCE Secrets Manager for DEW add-on (formerly dew-provider) interconnects with DEW. This add-on allows you to mount secrets stored outside a cluster (DEW for storing sensitive information) to pods. In this way, sensitive information can be decoupled from the cluster environments. This prevents information leakage caused by program hardcoding or plaintext configuration. For details, see CCE Secrets Manager for DEW.
