Using CCE Clusters Securely
To ensure security in a cluster, configure the cluster based on the suggestions below.
Using the Latest Cluster Version
Kubernetes releases a major version every four months. CCE follows the same frequency as Kubernetes to release major versions. To be specific, a new CCE version is released about three months after a new Kubernetes version is released in the community. For example, Kubernetes v1.19 was released in September 2020 and CCE v1.19 was released in March 2021.
The latest cluster version has known vulnerabilities fixed and provides a more comprehensive security protection system. You are advised to select the latest cluster version when creating a cluster. Upgrade your cluster to a supported version before the current version is deprecated or removed.
Handling Vulnerabilities Released on the Official Website Promptly
CCE releases vulnerabilities irregularly. You need to fix the vulnerabilities in a timely manner. For details, see Vulnerability Fixing Policies.
Disabling Automatic Token Mounting for the Default Service Account
By default, Kubernetes associates the default service account to each pod. This means that a token is attached to the containers. This token can be authenticated by kube-apiserver and kubelet. In a cluster with RBAC disabled, the service account that owns the token has control permissions for the entire cluster. In a cluster with RBAC enabled, the permissions of the service account that owns the token depend on the roles associated by the administrator. The service account's token is generally used by workloads that need to access kube-apiserver, such as CoreDNS, Autoscaler, and Prometheus. For workloads that do not need to access kube-apiserver, you are advised to disable the automatic association between the service account and token.
You can use either of the following methods to disable the automatic association:
- Set the automountServiceAccountToken field of the service account to false. After the configuration is complete, any newly created workload will not be associated with the default service account by default. You need to configure this parameter for each namespace as required.
apiVersion: v1 kind: ServiceAccount metadata: name: default automountServiceAccountToken: false ...When a workload needs to be associated with the service account, you should explicitly set automountServiceAccountToken to true in the workload YAML file.
... spec: template: spec: serviceAccountName: default automountServiceAccountToken: true ... - Explicitly disable the function of automatically associating the service account with workloads.
... spec: template: spec: automountServiceAccountToken: false ...
Configuring Proper Cluster Access Permissions for Users
CCE allows you to create multiple IAM users. Your account can create different user groups and assign different access permissions to these user groups. When creating users, you can add them to the user groups with corresponding permissions. In this way, you can control user permissions in different regions and assign read-only permissions to certain users. You can also assign namespace permissions to users or user groups. To ensure security, assign the minimum user access permissions.
To create multiple IAM users under an account, configure the permissions of the users and namespaces properly.
- For details about how to configure cluster permissions, see Cluster Permissions (IAM-based).
- For details about how to configure namespace permissions, see Namespace Permissions (Kubernetes RBAC-based).
Configuring Resource Quotas for a Namespace
The total number of resources that can be allocated to each namespace should be limited. These resources include CPUs, memory, storage volumes, pods, Services, Deployments, and StatefulSets. Proper configuration can prevent excessive resources created in a namespace from affecting the stability of the entire cluster.
For details, see Configuring Resource Quotas.
Configuring LimitRanges for Containers in a Namespace
With resource quotas, cluster administrators can limit the use and creation of resources by namespace. In a namespace, a pod or container can use the maximum CPUs and memory defined by a resource quota. In this way, the pod or container may take up all available resources. It is advised to configure LimitRanges to restrict resource allocation in namespaces. LimitRanges can:
- Limit the minimum and maximum resource usage of each pod or container in a namespace.
For example, configure the maximum and minimum CPU usage for a pod in a namespace as follows:
cpu-constraints.yaml
apiVersion: v1 kind: LimitRange metadata: name: cpu-min-max-demo-lr spec: limits: - max: cpu: "800m" min: cpu: "200m" type: ContainerRun kubectl -n <namespace> create -f cpu-constraints.yaml to complete the creation. If the default CPU usage is not specified for the container, CCE will automatically configure the default CPU usage. This means that the default configuration is automatically added after the container is created.
... spec: limits: - default: cpu: 800m defaultRequest: cpu: 800m max: cpu: 800m min: cpu: 200m type: Container - Limit the maximum and minimum storage space that each PVC can request in a namespace.
apiVersion: v1 kind: LimitRange metadata: name: storagelimit spec: limits: - type: PersistentVolumeClaim max: storage: 2Gi min: storage: 1GiRun kubectl -n <namespace> create -f storagelimit.yaml to complete the creation.
Configuring Network Isolation
- Container tunnel network
If networks need to be isolated between namespaces in a cluster or between workloads in the same namespace, you can use network policies. For details, see Configuring Network Policies to Restrict Pod Access.
- Cloud Native 2.0 network
For a cluster using a Cloud Native 2.0 network, you can use security groups to isolate networks between pods. For details, see Binding a Security Group to a Workload Using a Security Group Policy.
- VPC network
Enabling Webhook Authentication for kubelet
CCE clusters of v1.15.6-r1 or earlier are involved, whereas versions later than v1.15.6-r1 are not.
Upgrade the CCE cluster version to 1.13 or 1.15 and enable RBAC for the cluster. If the version is v1.13 or later, no upgrade is required.
When creating a node, you can enable kubelet authentication by injecting the postinstall file (by configuring the kubelet startup parameter --authorization-node=Webhook).
- Create a ClusterRoleBinding.
kubectl create clusterrolebinding kube-apiserver-kubelet-admin --clusterrole=system:kubelet-api-admin --user=system:kube-apiserver
- For an existing node, log in to the node, change authorization mode in /var/paas/kubernetes/kubelet/kubelet_config.yaml to Webhook, and restart kubelet.
sed -i s/AlwaysAllow/Webhook/g /var/paas/kubernetes/kubelet/kubelet_config.yaml; systemctl restart kubelet
- For a new node, add the command below to the post-installation script to change the kubelet authentication mode.
Uninstalling Kubernetes Web Terminal After Use
The Kubernetes Web Terminal add-on can be used to manage CCE clusters. Keep the login password secure to prevent unexpected operation and uninstall the add-on when it is no longer needed.
Using Physical Multi-Tenancy
To ensure that resources of different tenants are isolated and to reduce the attack surface, a separate CCE cluster can be created for each tenant. However, this solution comes with some drawbacks.
- High costs: It may increase the costs as more hardware or VM resources need to be purchased, and more workforce and time need to be spent on managing and maintaining these clusters.
- Low resource utilization: Each tenant requires separate hardware or VM resources to run their clusters, which may result in low resource utilization and wastage.
- Complex management: Managing and maintaining separate clusters for each tenant increase management complexity and may require more workforce and time.
Using Secure Containers
Compared with a common runtime, a secure runtime allows each pod to run on its own micro-VM with a separate OS kernel and ensures secure isolation at the virtualization layer. A secure runtime ensures that kernels, compute resources, and networks are isolated between pods, protecting pod resources and data from any potential theft or interference by other pods. In CCE Turbo clusters, you can deploy workloads using secure runtimes. You can buy physical machines in CCE Turbo clusters and opt to use the containerd container runtimes for secure containers.
