Using a Dual-Architecture Image (x86 and Arm)
Background
CCE allows you to create x86 and Arm nodes in the same cluster. Due to different underlying architectures, Arm images (applications) cannot run on x86 nodes, and vice versa. As a result, workloads may fail to be deployed in the cluster containing both x86 and Arm nodes.
Solution
Use either of the following methods:
- Configure service affinity when you create a workload so that the pod can be scheduled to an Arm node when an Arm image is used or to an x86 node when an x86 image is used.
- Build a dual-architecture image that supports both x86 and Arm. When a pod is scheduled to an Arm node, the Arm variant in the image is pulled. When a pod is scheduled to an x86 node, the x86 variant in the image is pulled. A dual-architecture image has two variants but has one unified access path. When deploying a workload, you only need to specify one image address without configuring the service affinity. In this case, the workload description file is simpler and easier to maintain.
Affinity Configuration Description
When creating a node, CCE automatically adds the kubernetes.io/arch label to the node. This label specifies the node architecture.
kubernetes.io/arch=amd64
The value amd64 indicates the x86 architecture, and arm64 indicates the Arm architecture.
When creating a workload, you can configure the node affinity to schedule pods to nodes using the corresponding architecture.
You can use nodeSelector in the YAML file to configure the architecture.
apiVersion: apps/v1
kind: Deployment
selector:
matchLabels:
app: test
template:
labels:
app: test
nodeSelector:
kubernetes.io/arch: amd64
containers:
- name: container0
image: swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend-linux-amd64:1.5
resources:
limits:
cpu: 250m
memory: 512Mi
requests:
cpu: 250m
memory: 512Mi
imagePullSecrets:
- name: default-secret Building a Dual-Architecture Image
To create a dual-architecture image, ensure that the Docker client version is later than 18.03.
The essence of building a dual-architecture image is to build images based on the x86 and Arm architectures separately and then build the dual-architecture image manifest.
For example, the defaultbackend-linux-amd64:1.5 and defaultbackend-linux-arm64:1.5 are images based on the x86 and Arm architectures, respectively.
Upload the two images to SWR. For details about how to upload an image, see Pushing an Image.
# Add a tag to the original amd64 image defaultbackend-linux-amd64:1.5. docker tag defaultbackend-linux-amd64:1.5 swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend-linux-amd64:1.5 # Add a tag to the original arm64 image defaultbackend-linux-arm64:1.5. docker tag defaultbackend-linux-arm64:1.5 swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend-linux-arm64:1.5 # Push the amd64 image to the image repository. docker push swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend-linux-amd64:1.5 # Push the arm64 image to the image repository. docker push swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend-linux-arm64:1.5
Create a dual-architecture manifest file and upload it.
# Enable DOCKER_CLI_EXPERIMENTAL. export DOCKER_CLI_EXPERIMENTAL=enabled # Create the manifest image file. docker manifest create --amend --insecure swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend:1.5 swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend-linux-arm64:1.5 swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend-linux-amd64:1.5 # Add arch information to the manifest image file. docker manifest annotate swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend:1.5 swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend-linux-amd64:1.5 --arch amd64 docker manifest annotate swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend:1.5 swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend-linux-arm64:1.5 --arch arm64 # Push the manifest image file to the image repository. docker manifest push -p --insecure swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend:1.5
In this way, you only need to use the image address swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend:1.5 when creating a workload.
- When a pod created from this image is scheduled to an x86 node, the swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend-linux-amd64:1.5 image will be pulled.
- When a pod created from this image is scheduled to an Arm node, the swr.ap-southeast-1.myhuaweicloud.com/test-namespace/defaultbackend-linux-arm64:1.5 image will be pulled.
