Performing RBAC Authentication on a Namespace Using kubectl
Background
CCE permissions are classified into cluster permissions and namespace permissions. Namespace permissions are based on Kubernetes RBAC and can be used to grant permissions on resources in clusters and namespaces.
The CCE console provides four default ClusterRoles: cluster-admin, admin, edit, and view. These roles apply uniformly to all resources within a namespace. However, they do not allow granular permission configuration (create, delete, modify, and get) for specific resource types, such as pods, Deployments, or Services, within that namespace.
Solution
Kubernetes RBAC enables you to easily control permissions on namespace resources.
- Roles: define a set of rules for accessing Kubernetes resources in a namespace.
- RoleBindings: define the relationship between users and roles.
- ClusterRoles: define a set of rules for accessing Kubernetes resources in a cluster (including all namespaces).
- ClusterRoleBindings: define the relationship between users and cluster roles.
Roles and ClusterRoles specify actions that can be performed on specific resources. RoleBindings and ClusterRoleBindings bind Roles to specific users, user groups, or service accounts.
The user in this figure can be an IAM user or user group in CCE. You can efficiently control permissions on namespace resources through RoleBindings.
The section describes how to use Kubernetes RBAC to grant user-example with the permission to view pods. This is the only permission the user has.
This function applies only to clusters of v1.11.7-r2 or later because only such clusters support RBAC.
Creating an IAM User and User Group
Log in to the IAM console and create an IAM user named user-example and a user group named cce-role-group. For details about how to create an IAM user and user group, see Creating an IAM User and Logging In and Creating a User Group and Assigning Permissions.
Grant the CCE FullAccess permission to the cce-role-group user group. For details about how to grant permissions to a user group, see Creating a User Group and Assigning Permissions.
CCE FullAccess has the permissions for cluster operations (such as cluster creation), but does not have the permissions to operate Kubernetes resources (such as viewing pods).
Creating a Cluster
Log in to CCE and create a cluster.
Do not use IAM user user-example to create a cluster because CCE automatically assigns the user who creates the cluster the cluster-admin permissions for all namespaces. That is, the user can fully control the resources in the cluster and all its namespaces.
Log in to the CCE console as IAM user user-example, download the kubectl configuration file in the cluster and access the cluster, and run the command below to obtain the pod information. The output shows that user-example does not have the permission to view the pods or other resources. This indicates that user-example does not have the permissions to operate Kubernetes resources.
# kubectl get pod Error from server (Forbidden): pods is forbidden: User "0c97ac3cb280f4d91fa7c0096739e1f8" cannot list resource "pods" in API group "" in the namespace "default" # kubectl get deploy Error from server (Forbidden): deployments.apps is forbidden: User "0c97ac3cb280f4d91fa7c0096739e1f8" cannot list resource "deployments" in API group "apps" in the namespace "default"
Creating a Role and RoleBinding
Log in to the CCE console, download the kubectl configuration file in the cluster, access the cluster, and create a Role and RoleBinding.
Log in as the account used to create the cluster because CCE automatically assigns the cluster-admin permissions to the account, which means that the account has the permissions to create Roles and RoleBindings. Alternatively, you can use IAM users who have the permissions to create Roles and RoleBindings.
The definition of a Role is simple. You just specify a namespace and some rules. For example, the following rules allow you to perform GET and LIST operations on pods in the default namespace.
kind: Role apiVersion: rbac.authorization.k8s.io/v1 metadata: namespace: default # Namespace name: role-example rules: - apiGroups: [""] resources: ["pods"] # The pod can be accessed. verbs: ["get", "list"] # The GET and LIST operations can be performed.
- apiGroups indicates the API group to which the resource belongs.
- resources indicates the resources that can be operated. Pods, Deployments, ConfigMaps, and other Kubernetes resources are supported.
- verbs indicates the operations that can be performed. get indicates querying a specific object, and list indicates listing all objects of a certain type. Other value options include create, update, and delete.
For details, see Using RBAC Authorization.
After creating a Role, you can bind the Role to a specific user. This is called RoleBinding. The following shows an example:
kind: RoleBinding
namespace: default
annotations:
CCE.com/IAM: 'true'
roleRef:
kind: Role
apiGroup: rbac.authorization.k8s.io
subjects:
- kind: User
name: 0c97ac3cb280f4d91fa7c0096739e1f8 # IAM user ID
apiGroup: rbac.authorization.k8s.io The subjects section binds a Role to an IAM user so that the IAM user can obtain the permissions defined in the Role, as shown in the figure below.
You can also specify a user group in the subjects section. In this case, all users in the user group obtain the permissions defined in the Role.
subjects: - kind: Group name: 0c96fad22880f32a3f84c009862af6f7 # User group ID apiGroup: rbac.authorization.k8s.io
Verification
Use the IAM user user-example to access the cluster and view the pods. You can view the pods.
# kubectl get pod NAME READY STATUS RESTARTS AGE nginx-658dff48ff-7rkph 1/1 Running 0 4d9h nginx-658dff48ff-njdhj 1/1 Running 0 4d9h # kubectl get pod nginx-658dff48ff-7rkph NAME READY STATUS RESTARTS AGE nginx-658dff48ff-7rkph 1/1 Running 0 4d9h
Try querying Deployments and Services in the namespace. The output shows that user-example does not have the corresponding permission. Try querying the pods in the kube-system namespace. The output shows user-example does not have the corresponding permission, either. This indicates that the IAM user user-example has only the GET and LIST pod permissions in the default namespace, which is the same as expected.
# kubectl get deploy Error from server (Forbidden): deployments.apps is forbidden: User "0c97ac3cb280f4d91fa7c0096739e1f8" cannot list resource "deployments" in API group "apps" in the namespace "default" # kubectl get svc Error from server (Forbidden): services is forbidden: User "0c97ac3cb280f4d91fa7c0096739e1f8" cannot list resource "services" in API group "" in the namespace "default" # kubectl get pod --namespace=kube-system Error from server (Forbidden): pods is forbidden: User "0c97ac3cb280f4d91fa7c0096739e1f8" cannot list resource "pods" in API group "" in the namespace "kube-system"
