Installing Spark
A Linux server that can access the Internet is available. The recommended node flavor is 4 vCPUs and 8 GiB of memory or higher.
Configuring the JDK
This section uses CentOS as an example to describe how to install JDK 1.8.
- Obtain the available version.
yum -y list java*
- Install JDK 1.8.
yum install -y java-1.8.0-openjdk java-1.8.0-openjdk-devel
- Check the version after the installation.
# java -version openjdk version "1.8.0_382" OpenJDK Runtime Environment (build 1.8.0_382-b05) OpenJDK 64-Bit Server VM (build 25.382-b05, mixed mode)
- Add environment variables.
- Linux environment variables are configured in the /etc/profile file.
vim /etc/profile
- In the editing mode, add the following content to the end of the file:
JAVA_HOME=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.382.b05-1.el7_9.x86_64 PATH=$PATH:$JAVA_HOME/bin CLASSPATH=.:$JAVA_HOME/lib/dt.jar:$JAVA_HOME/lib/tools.jar export JAVA_HOME PATH CLASSPATH
- Save and close the profile file. Run the following command for the modification to take effect:
source /etc/profile
- Check the JDK environment variables.
echo $JAVA_HOME echo $PATH echo $CLASSPATH
Obtaining the Spark Package
OBS matches Hadoop 2.8.3 and 3.1.1. Hadoop 3.1.1 is used in this example.
- Download Spark v3.1.1. If Git is not installed, run yum install git to install it.
git clone -b v3.1.1 https://github.com/apache/spark.git
- Modify the /dev/make-distribution.sh file and specify the Spark version so that the check can be skipped during compilation.
- Search for the line where VERSION resides and check the number of the line where the version number is located.
cat ./spark/dev/make-distribution.sh |grep -n '^VERSION=' -A18
- Comment out the content displayed from lines 129 to 147 and specify the version.
sed -i '129,147s/^/#/g' ./spark/dev/make-distribution.sh sed -i '148a VERSION=3.1.3\nSCALA_VERSION=2.12\nSPARK_HADOOP_VERSION=3.1.1\nSPARK_HIVE=1' ./spark/dev/make-distribution.sh
- Download dependencies.
wget https://archive.apache.org/dist//maven/maven-3/3.6.3/binaries/apache-maven-3.6.3-bin.tar.gz tar -zxvf apache-maven-3.6.3-bin.tar.gz && mv apache-maven-3.6.3 ./spark/build
- Perform compilation.
./spark/dev/make-distribution.sh --name hadoop3.1 --tgz -Pkubernetes -Pyarn -Dhadoop.version=3.1.1
- Wait for the compilation to complete. After the compilation, the software package is named spark-3.1.3-bin-hadoop3.1.tgz.
Configuring the Runtime Environment for Spark
To simplify the operation, use the root user to place the spark-3.1.3-bin-hadoop3.1.tgz package in the /root directory on the operation node.
- Move the software package to the /root directory.
mv ./spark/spark-3.1.3-bin-hadoop3.1.tgz /root
- Install Spark.
tar -zxvf spark-3.1.3-bin-hadoop3.1.tgz mv spark-3.1.3-bin-hadoop3.1 spark-obs cat >> ~/.bashrc <<EOF PATH=/root/spark-obs/bin:\$PATH PATH=/root/spark-obs/sbin:\$PATH export SPARK_HOME=/root/spark-obs EOF source ~/.bashrc
- Run the following command where binary spark-submit is used to check the Spark version:
spark-submit --version
Interconnecting Spark with OBS
- Obtain Huawei Cloud OBS JAR. The hadoop-huaweicloud-3.1.1-hw-45.jar package is used, which can be obtained from https://github.com/huaweicloud/obsa-hdfs/tree/master/release.
wget https://github.com/huaweicloud/obsa-hdfs/releases/download/v45/hadoop-huaweicloud-3.1.1-hw-45.jar
- Copy the package to the corresponding directory.
cp hadoop-huaweicloud-3.1.1-hw-45.jar /root/spark-obs/jars/
- Modify the Spark ConfigMaps. To interconnect Spark with OBS, add ConfigMaps for Spark as follows:
- Obtain the AK/SK. For details, see Access Keys.
- Change the values of AK_OF_YOUR_ACCOUNT, SK_OF_YOUR_ACCOUNT, and OBS_ENDPOINT to the actual values.
- AK_OF_YOUR_ACCOUNT: indicates the AK obtained in the previous step.
- SK_OF_YOUR_ACCOUNT: indicates the SK obtained in the previous step.
- OBS_ENDPOINT: indicates the OBS endpoint. It can be obtained in Regions and Endpoints.
cp ~/spark-obs/conf/spark-defaults.conf.template ~/spark-obs/conf/spark-defaults.conf cat >> ~/spark-obs/conf/spark-defaults.conf <<EOF spark.hadoop.fs.obs.readahead.inputstream.enabled=true spark.hadoop.fs.obs.buffer.max.range=6291456 spark.hadoop.fs.obs.buffer.part.size=2097152 spark.hadoop.fs.obs.threads.read.core=500 spark.hadoop.fs.obs.threads.read.max=1000 spark.hadoop.fs.obs.write.buffer.size=8192 spark.hadoop.fs.obs.read.buffer.size=8192 spark.hadoop.fs.obs.connection.maximum=1000 spark.hadoop.fs.obs.access.key=AK_OF_YOUR_ACCOUNT spark.hadoop.fs.obs.secret.key=SK_OF_YOUR_ACCOUNT spark.hadoop.fs.obs.endpoint=OBS_ENDPOINT spark.hadoop.fs.obs.buffer.dir=/root/hadoop-obs/obs-cache spark.hadoop.fs.obs.impl=org.apache.hadoop.fs.obs.OBSFileSystem spark.hadoop.fs.obs.connection.ssl.enabled=false spark.hadoop.fs.obs.fast.upload=true spark.hadoop.fs.obs.socket.send.buffer=65536 spark.hadoop.fs.obs.socket.recv.buffer=65536 spark.hadoop.fs.obs.max.total.tasks=20 spark.hadoop.fs.obs.threads.max=20 spark.kubernetes.container.image.pullSecrets=default-secret EOF
Pushing an Image to SWR
To run Spark tasks in Kubernetes, build a Spark container image of the same version and upload it to SWR. A Dockerfile file has been generated during compilation. Use this file to create an image and push it to SWR.
- Create an image.
cd ~/spark-obs docker build -t spark:3.1.3-obs --build-arg spark_uid=0 -f kubernetes/dockerfiles/spark/Dockerfile .
- Upload the image.
- (Optional) Log in to the SWR console, choose Organizations in the navigation pane, and click Create Organization in the upper right corner.
Skip this step if you already have an organization.
- Choose My Images in the navigation pane and click Upload Through Client. On the page displayed, click Generate Login Command and click
to copy the command. - Run the copied login command on the node. If the login is successful, the message "Login Succeeded" is displayed.
- Log in to the node where the image is created and run the login command.
docker tag [{image name}:{tag}] swr.ap-southeast-1.myhuaweicloud.com/{organization name}/{image name}:{tag} docker push swr.ap-southeast-1.myhuaweicloud.com/{organization name}/{image name}:{tag}Record the image address for later use.
For example, record the IP address as swr.ap-southeast-1.myhuaweicloud.com/dev-container/spark:3.1.3-obs.
Configuring a Spark History Server
- Modify the ~/spark-obs/conf/spark-defaults.conf file, enable Spark event logging, and configure the OBS bucket name and directory.
cat >> ~/spark-obs/conf/spark-defaults.conf <<EOF spark.eventLog.enabled=true spark.eventLog.dir=obs://{bucket-name}/{log-dir}/ EOF- spark.eventLog.enabled: indicates that Spark event logging is enabled if it is set to true.
- spark.eventLog.dir: indicates the OBS bucket name and path. The bucket is named in the format of obs://{bucket-name}/{log-dir}/, for example, obs://spark-sh1/history-obs/. Ensure that the OBS bucket name and directory are correct.
- Modify the ~/spark-obs/conf/spark-env.sh file. If the file does not exist, run the command to copy the template as a file:
cp ~/spark-obs/conf/spark-env.sh.template ~/spark-obs/conf/spark-env.sh cat >> ~/spark-obs/conf/spark-env.sh <<EOF SPARK_HISTORY_OPTS="-Dspark.history.fs.logDirectory=obs://{bucket-name}/{log-dir}/" EOFThe OBS address must be the same as that in spark-default.conf in the previous step.
- Start the Spark History Server.
start-history-server.sh
Information similar to the following is displayed:
starting org.apache.spark.deploy.history.HistoryServer, logging to /root/spark-obs/logs/spark-root-org.apache.spark.deploy.history.HistoryServer-1-spark-sh1.out
- Access the server through port 18,080 on the node.
To stop the server, run the following command:
stop-history-server.sh
