Help Center/Cloud Container Engine/Best Practices/Batch Computing/Deploying and Using Caffe in a CCE Cluster/Preparing Resources
Updated on 2026-03-10 GMT+08:00
Preparing Resources
Adding a GPU Node to a Cluster
- Log in to the CCE console and click the name of the cluster to access the cluster console.
- Install the CCE AI Suite (NVIDIA GPU) add-on.
- In the navigation pane, choose Add-ons. Locate CCE AI Suite (NVIDIA GPU) and click Install.
- In the window that slides out from the right, configure the key parameters.
- NVIDIA Driver: Enter the download link of the NVIDIA driver. Select a driver based on the graphics card model of the GPU node.
Retain the default values for other parameters. For details, see CCE AI Suite (NVIDIA GPU).
- Click Install.
- Create a GPU node.
- In the navigation pane, choose Nodes. In the right pane, click the Nodes tab, click Create Node in the upper right corner, and configure the parameters.
- Select GPU-accelerated for Specifications and configure other parameters as required. For details, see Creating a Node.
- After the configuration, click Next: Confirm. On the page displayed, confirm the configuration and click Submit.
- View its status in the node list.
Importing an OBS Volume
Go to the storage page and import the OBS volume created in Pre-configuring OBS Storage Data.
