Updated on 2026-09-08 GMT+08:00
Solution Overview
This section provides CCE best practices to walk you through the application containerization.
What Is a Container?
A container is a lightweight high-performance resource isolation mechanism implemented based on the Linux kernel. It is a built-in capability of the operating system (OS) kernel.
CCE is an enterprise-class container service based on open-source Kubernetes. It is a high-performance and high-reliability service through which enterprises can manage containerized applications. CCE supports native Kubernetes applications and tools, allowing you to easily set up a container runtime in the cloud.
Why Is a Container Preferred?
  • More efficient use of system resources
    A container does not need extra overheads such as hardware virtualization or running of a complete OS. This makes it more efficient in using system resources. Compared with a VM with the same configurations, a container can run more applications.
  • Faster startup
    A container directly runs on the host kernel and does not need to start a complete OS. Therefore, a container can be started within seconds or even milliseconds, greatly saving the development, testing, and deployment time.
  • Consistent runtime environment
    A container image provides a complete runtime environment to ensure environment consistency. In this case, problems (for example, some code runs properly on machine A but fails to run on machine B) will not occur.
  • Easier application migration, maintenance, and scaling
    A consistent runtime environment makes application migration easier. In addition, the in-use storage and image technologies facilitate the reuse of repeated applications and simplifies the expansion of images based on base images.
How to Containerize an Application
To containerize an application, you can:
  • Containerize an entire monolithic application without changing the code and architecture.
  • Containerize first the application components that are frequently updated or have high auto scaling requirements.
  • Break the application down into microservices and then containerize them.
Table 1 lists the advantages and disadvantages of the three modes.
Table 1 Containerization modes
How to Containerize
Advantage
Disadvantage
Method 1:
Containerize an entire monolithic application.
  • Zero modification: Application architectures and code require no changes.
  • Efficient deployment and upgrade: Applications can be packaged as container images to ensure consistent environment and improve deployment efficiency.
  • Reduced costs: Containers use system resources more efficiently. Compared with VMs, a host with the same specifications can run more applications.
  • Difficult to expand the entire architecture of an application. As code size increases, code update and maintenance become complicated.
  • Difficult to use new functions, languages, frameworks, and technologies.
Method 2:
  • Progressive transformation: Reconstructing the entire architecture is labor-intensive. Progressive containerization is more feasible.
  • Flexible scaling: Containerizing components with high auto scaling requirements and just scaling these containers enhance flexibility and reduce the number of system resources needed.
  • Faster rollout: Containerizing the components that are updated frequently and only upgrading these containers enable faster rollout of new features.
Services need to be partially decoupled.
Method 3:
Break an application down into microservices and then containerize them.
  • Independent scaling: After an application is split into groups of microservices, you can adjust the number of pods for each microservice separately.
  • Faster development: Microservices run independently. They do not impact each other during code development.
  • Enhanced security through isolation: In a monolithic application, a security vulnerability can grant access to all functions. However, in microservices, if one service is attacked, only the permissions of that specific service are compromised, preventing intrusion into other services.
  • Stabler services: If one microservice breaks down, other microservices can still run properly.
Breaking down services into microservices requires numerous changes.
Mode 1 is used as an example in this tutorial to illustrate how to containerize an enterprise resource planning (ERP) system.
