Graceful Startup of a Spring Cloud Application
Overview
This section describes how to configure graceful startup for Spring Cloud application to perform operations such as upgrade, restart, and scale-out during component O&M.
- You have created an environment.
- You have created an application.
- You have created and deployed a Spring Cloud component.
- Enable spring-boot-starter-actuator for Spring Cloud.
- Add the spring-boot-starter-actuator dependency to the pom.xml file of the source code corresponding to the component. (Version 2.3.0 or later is recommended.)
<dependency> <groupId>org.springframework.boot</groupId> <artifactId>spring-boot-starter-actuator</artifactId> <version>{Your Spring boot version}</version> </dependency> - Add the following configurations to the application.properties file:
Table 1 application.properties Spring Boot Version
Configuration
2.3.0/2.3.1
management.health.probes.enabled=true
>= 2.3.2
management.endpoint.health.probes.enabled=true
management.health.livenessState.enabled=true
management.health.readinessState.enabled=true
- Update code.
- If your component is deployed using source code, update the modified source code to the source code repository.
- If your component is deployed using a software package, pack the new code into a software package and upload the new package to the software package repository.
- Use the new source code or software package to upgrade the component.
- Configure component health check.
- Log in to CAE. Choose Component Configurations.
- Select the target component from the drop-down list in the upper part of the page.
- Configure readiness probe by referring to Configuring Health Check. The parameters are as follows:
Table 2 Readiness probe parameters Parameter
Check Method
Select HTTP.
Port
Enter the listening port of your component.
Path
- For Spring Boot 2.3 and later, enter /actuator/health/readiness.
- For Spring Boot versions earlier than 2.3, enter /actuator/health.
Protocol
Select the protocol of your component.
Check Interval
Enter 10.
Latency
Enter 0.
Timeout Interval
Enter 1.
Success Threshold
Enter 1.
Failure Threshold
Enter 3.
- Upgrade the component. For details, see Upgrading a Component.
- Verify the configuration.
- Choose Components. If the status of the target component is Running, go to the next step. Otherwise, the configuration fails.
- Choose Component Events and select the target component from the drop-down list in the upper part of the page. If the Component instance healthy event exists, the configuration is successful. Otherwise, the configuration fails.
