StatefulSets
Overview of StatefulSets
All pods under a Deployment are identical except for their names and IP addresses. Deployments can create new pods using a pod template and delete any pod when not needed.
However, Deployments are not suitable for distributed scenarios where each pod requires its own status or independent storage, such as in distributed databases.
Distributed stateful applications often involve different roles and responsibilities. For example, databases may operate in active/standby mode, and pods may depend on each other. To deploy stateful applications in Kubernetes, pods must meet the following requirements:
- Each pod must have a unique, fixed identifier to be recognized by other pods.
- Each pod should be configured with separate storage resources to ensure data persistence. This allows the original data to be retained and retrieved even after a pod is deleted and recreated. Without dedicated storage, the pod's data will be lost upon deletion, and the new pod will initialize with a different state.
To address these requirements, Kubernetes provides StatefulSets:
- StatefulSets provide a fixed name for each pod, followed by a sequential numeric suffix (for example, pod-0, pod-1, ..., pod-N). After a pod is rescheduled, its name and hostname remain unchanged.
- StatefulSets use a headless Service to allocate a fixed domain name for each pod.
- StatefulSets create PVCs with fixed identifiers. This ensures that pods can access the original persistent data after being rescheduled. Figure 1 StatefulSet
Creating a Headless Service
A headless Service is required by a StatefulSet to access its pods.
Define a headless Service as follows:
- spec.clusterIP: must be set to None to indicate a headless Service.
- spec.ports.port: the port for communication between pods.
- spec.ports.name: the name of the port for communication between pods.
apiVersion: v1
kind: Service # The object type is Service.
labels:
app: nginx
ports:
- name: nginx # The name of the port for communication between pods
port: 80 # The port for communication between pods
selector:
app: nginx # Select the pods labeled with app:nginx.
clusterIP: None # Set this parameter to None to indicate a headless Service. Create the headless Service.
# kubectl create -f headless.yaml service/nginx created
After the Service is created, check the Service information.
# kubectl get svc NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE nginx ClusterIP None <none> 80/TCP 5s
Creating a StatefulSet
The YAML definition of a StatefulSet is similar to that of other Kubernetes objects. The differences are as follows:
- serviceName specifies the headless Service used by the StatefulSet. This parameter is required.
- volumeClaimTemplates defines a template for requesting PVCs. In this example, a template named data is defined, which creates a PVC for each pod. The storageClassName field specifies the type of persistent storage. For details, see PVs, PVCs, and Storage Classes. The volumeMounts field specifies where the storage is mounted on the pods. If no persistent storage is required, you can delete volumeClaimTemplates and volumeMounts.
apiVersion: apps/v1
kind: StatefulSet
serviceName: nginx # The name of the headless Service
replicas: 3
selector:
matchLabels:
app: nginx
template:
labels:
app: nginx
containers:
- name: container-0
image: nginx:alpine
resources:
limits:
cpu: 100m
memory: 200Mi
requests:
cpu: 100m
memory: 200Mi
volumeMounts: # The storage to be mounted on the pods
- name: data
mountPath: /usr/share/nginx/html # Mount storage to /usr/share/nginx/html.
imagePullSecrets:
- name: default-secret
volumeClaimTemplates:
- metadata:
accessModes:
- ReadWriteMany
resources:
requests:
storage: 1Gi
storageClassName: csi-nas # The type of persistent storage Create the StatefulSet.
# kubectl create -f statefulset.yaml statefulset.apps/nginx created
After executing the command, verify the StatefulSet and its pods. Pod names will have sequential numeric suffixes starting from 0 and incrementing up to 2.
# kubectl get statefulset NAME READY AGE nginx 3/3 107s # kubectl get pods NAME READY STATUS RESTARTS AGE nginx-0 1/1 Running 0 112s nginx-1 1/1 Running 0 69s nginx-2 1/1 Running 0 39s
Delete the pod named nginx-1 and recheck the pods. A new pod with the same name (nginx-1) will be created. The value 5s under the AGE field indicates that the new pod was recently created.
# kubectl delete pod nginx-1 pod "nginx-1" deleted # kubectl get pods NAME READY STATUS RESTARTS AGE nginx-0 1/1 Running 0 3m4s nginx-1 1/1 Running 0 5s nginx-2 1/1 Running 0 1m10s
Access the pods and check their hostnames. They remain as nginx-0, nginx-1, and nginx-2.
# kubectl exec nginx-0 -- sh -c 'hostname' nginx-0 # kubectl exec nginx-1 -- sh -c 'hostname' nginx-1 # kubectl exec nginx-2 -- sh -c 'hostname' nginx-2
Verify the PVCs created by the StatefulSet. These PVCs are named in the format "PVC name-StatefulSet name-Number" and are in the Bound state.
# kubectl get pvc NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS AGE data-nginx-0 Bound pvc-f58bc1a9-6a52-4664-a587-a9a1c904ba29 1Gi RWX csi-nas 2m24s data-nginx-1 Bound pvc-066e3a3a-fd65-4e65-87cd-6c3fd0ae6485 1Gi RWX csi-nas 101s data-nginx-2 Bound pvc-a18cf1ce-708b-4e94-af83-766007250b0c 1Gi RWX csi-nas 71s
Network Identifier of a StatefulSet
After a StatefulSet is created, each of its pods is assigned a fixed name. The headless Service used by the StatefulSet provides a fixed domain name for each pod via DNS. This allows pods to communicate with each other using their domain names. These names remain unchanged even if a pod's IP address changes after the pod is recreated.
After a headless Service is created, it allocates a domain name in the following format to each pod:
<pod-name>.<svc-name>.<namespace>.svc.cluster.local
For example, the domain names for the preceding three pods are as follows:
- nginx-0.nginx.default.svc.cluster.local
- nginx-1.nginx.default.svc.cluster.local
- nginx-2.nginx.default.svc.cluster.local
In practice, .<namespace>.svc.cluster.local can be omitted when accessing pods.
To verify DNS resolution, create a pod using the tutum/dnsutils image. Access the container and run nslookup to resolve the pod's domain name. The pod's IP address should be correctly resolved. The IP address of the DNS server is 10.247.3.10. When a CCE cluster is created, the CoreDNS add-on is installed by default to provide the DNS service. For details, see Kubernetes Networks.
$ kubectl run -i --tty --image tutum/dnsutils dnsutils --restart=Never --rm /bin/sh If you don't see a command prompt, try pressing enter. / # nslookup nginx-0.nginx Server: 10.247.3.10 Address: 10.247.3.10#53 Name: nginx-0.nginx.default.svc.cluster.local Address: 172.16.0.31 / # nslookup nginx-1.nginx Server: 10.247.3.10 Address: 10.247.3.10#53 Name: nginx-1.nginx.default.svc.cluster.local Address: 172.16.0.18 / # nslookup nginx-2.nginx Server: 10.247.3.10 Address: 10.247.3.10#53 Name: nginx-2.nginx.default.svc.cluster.local Address: 172.16.0.19
Manually delete the two pods. After the StatefulSet recreates the pods, check their IP addresses. Then, run nslookup to resolve the domain names of the pods. You should still be able to resolve nginx-0.nginx and nginx-1.nginx. This ensures that the network identity of the StatefulSet remains unchanged.
Storage Status of a StatefulSet
As mentioned above, StatefulSets use PVCs for persistent storage. This ensures that the original data remains accessible even after pods are rescheduled. When pods are deleted, the PVCs are retained.
The following uses an example to illustrate the process. Write data to the /usr/share/nginx/html directory of nginx-1. For example, modify the content of index.html to display hello world by running the following command:
# kubectl exec nginx-1 -- sh -c 'echo hello world > /usr/share/nginx/html/index.html'
After modifying the content, access https://localhost. The response should be hello world.
# kubectl exec -it nginx-1 -- curl localhost hello world
Delete the pod named nginx-1 and recheck the pods. A new pod with the same name (nginx-1) will be created. The value 4s under the AGE field indicates that the new pod was recently created.
# kubectl delete pod nginx-1 pod "nginx-1" deleted # kubectl get pods NAME READY STATUS RESTARTS AGE nginx-0 1/1 Running 0 14m nginx-1 1/1 Running 0 4s nginx-2 1/1 Running 0 13m
Re-access the index.html of the newly created nginx-1 pod. The content hello world is still returned. This confirms that the new pod continues to access the original storage data.
