Updated on 2025-01-20 GMT+08:00
Viewing Results in a Chart
SecMaster supports a wide range of chart types to display query and analysis results. You can select the one you like.
SecMaster can display query and analysis results in the following types of charts:
Procedure for Viewing Results in a Chart
The query and analysis results can be displayed in a table, line chart, bar chart, or pie chart.
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Threat Operations > Security Analysis. The security analysis page is displayed.
    Figure 2 Accessing the Security Analysis tab page
  5. In the data space navigation tree on the left, click a data space name to show the pipeline list. Click a pipeline name. On the displayed page, you can search the pipeline data.
    Figure 3 Pipeline data page
  6. Enter the query and analysis statement, set the time range, and click Query/Analyze.
  7. Select a chart type you need to display the query and analysis results.
    • Displaying query and analysis results in a table
      Tables are the most commonly used method to display and analyze data. In SecMaster, the data results of query and analysis statements are displayed in tables by default.
      Click the Charts tab. In the Chart Type area on the right of the page, click .
      Figure 4 Table statistics
      Configure table parameters.
      Table 1 Table parameters
      Parameter Category
      Base Settings
      Title
      Customized table title.
      Chart Settings
      Hidden Fields
      The field you want to hide it in the table.
      After the chart is configured, you can preview analysis results on the left.
    • Displaying query and analysis results in a line chart
      A line chart is used to display the change of a group of data in a period and show the data change trend.
      Figure 5 Line chart statistics
      Configure line chart parameters.
      Table 2 Line chart parameters
      Parameter Category
      Base Settings
      Title
      Customized line chart title.
      Chart Settings
      X-Axis Title
      Customized title of the X axis.
      Y-Axis Title
      Customized title of the Y axis.
      X-Axis Field
      Field to be displayed on the X axis.
      Y-Axis Field
      Field to be displayed on the Y axis.
      Legend
      Show Legend
      Whether to display the legend.
      Position
      This parameter is mandatory when you choose to show the legend.
      Position of the legend in the chart. The options are Top, Bottom, Left, and Right.
    • Displaying query and analysis results in a bar chart
      A bar chart presents categorical data with rectangular bars. It can be used to compare data and analyze trends. In SecMaster, a bar chart uses vertical bars (the width is fixed and the height indicates the value) to display data by default.
      Figure 6 Bar chart statistics
      Configure bar chart parameters.
      Table 3 Bar chart parameters
      Parameter Category
      Base Settings
      Title
      Chart Settings
      X-Axis Title
      Y-Axis Title
      X-Axis Field
      Y-Axis Field
      Legend
      Show Legend
      Position
    • Displaying query and analysis results in a pie chart
      A pie chart shows the proportion of different categories. Different categories are compared by radian.
      Figure 7 Pie chart statistics
      Configure pie chart parameters.
      Table 4 Pie chart parameters
      Parameter Category
      Base Settings
      Title
      Chart Settings
      Classify
      Data classification.
      Column Value
      The value corresponding to the categorized data.
      Legend
      Show Legend
      Position
      After the chart is configured, you can preview the analysis result on the left.
