Help Center/
Database Security Service/
User Guide (ME-Abu Dhabi Region)/
FAQs/
Agent/
How Do I Install the Agent (in Windows OS)?
Updated on 2023-01-10 GMT+08:00
To install the agent on a Windows OS, perform the following operations.
- You have added an agent to your database.
- You have obtained the agent installation package for the Windows OS.
- The Windows OS version of the target node is supported by the agent.
Installing an Agent
- Install Npcap on the Windows server.
- If Npcap has been installed on the Windows OS, go to 2.
- If the Npcap has not been installed on the Windows server, perform the following steps:
- Download the latest Npcap software installation package from https://nmap.org/npcap/.
Figure 1 Downloading Npcap
- Upload the npcap-xxxx.exe software installation package to the VM where the agent is to be installed.
- Double-click the Npcap installation package.
- In the displayed dialog box, click I Agree, as shown in Figure 2.
- In the displayed dialog box, leave all the check boxes unselected and click Install, as shown in Figure 3.
- In the displayed dialog box, click Next.
- Click Finish.
- Log in to the target Windows server as the Administrator user.
- Copy the downloaded .zip agent installation package to any directory on the server.
- Decompress the package.
- Double-click the install.bat file in the package directory.
- Press any key to complete installation after the output shown in Figure 4 is displayed.
- Check the installation result. If the dbss_audit_agent process can be found in the Windows Task Manager, the installation succeeded.
If it is not found, install the agent again.
Parent topic: Agent
