On What Windows Versions Can I Install the Agent?
To use database audit, you need to install its agent on database nodes or application nodes.
The agent can be installed on the following Windows versions:
- Windows Server 2008 R2 (64bit)
- Windows Server 2012 R2 (64bit)
- Windows Server 2016 (64bit)
- Windows 7 (64bit)
- Windows 10 (64bit)
The DBSS agent depends on Npcap. If the message "Npcap not found, please install Npcap first" is displayed when you install the DBSS agent, first install Npcap and then the DBSS agent.
