Updated on 2023-12-27 GMT+08:00
Database audit is subject to certain constraints.
Supported Database Types
The following types of databases on the management console can be audited in out-of-path mode:
  • Relational Database Service (RDS)
  • Databases built on ECS
  • Databases built on BMS
Databases That Need Agents
The following database versions can be audited.
Table 1 Database types and versions supported by database audit
Database Type
Edition
MySQL
  • 5.0, 5.1, 5.5, 5.6, 5.7
  • 8.0 (8.0.11 and earlier)
  • 8.0.23
Oracle
  • 11g
    11.1.0.6.0, 11.2.0.1.0, 11.2.0.2.0, 11.2.0.3.0, and 11.2.0.4.0
  • 12c
    12.1.0.2.0, 12.2.0.1.0
  • 19c
PostgreSQL
  • 7.4
  • 8.0
    8.0, 8.1, 8.2, 8.3, 8.4
  • 9.0
    9.0, 9.1, 9.2, 9.3, 9.4, 9.5, 9.6
  • 10.0
    10.0, 10.1, 10.2, 10.3, 10.4, 10.5
  • 11.0
  • 12.0
  • 13.0
SQL Server
  • 2008, 2008R2
  • 2012
  • 2014
  • 2016
  • 2017
DWS
  • 1.5
SHENTONG
V7.0
GBase 8a
V8.5
GBase 8s
V8.8
Gbase XDM Cluster
V8.0
TAURUS
MySQL 8.0
Supported OSs
To use database audit, you need to install its agent on database nodes or application nodes. The database audit agent can run on the 64-bit Linux or Windows.
  • For more information, see Table 2.
    Table 2 Supported Linux OS versions
    System Name
    System version
    CentOS
    • CentOS 7.0 (64bit)
    • CentOS 7.1 (64bit)
    • CentOS 7.2 (64bit)
    • CentOS 7.3 (64bit)
    • CentOS 7.4 (64bit)
    • CentOS 7.5 (64bit)
    • CentOS 7.6 (64bit)
    • CentOS 7.8 (64bit)
    • CentOS 8.0 (64bit)
    Debian
    • Debian 7.5.0 (64bit)
    • Debian 8.2.0 (64bit)
    • Debian 8.8.0 (64bit)
    • Debian 9.0.0 (64bit)
    Fedora
    • Fedora 24 (64bit)
    • Fedora 25 (64bit)
    SUSE
    • SUSE 11 SP4 (64bit)
    • SUSE 12 SP1 (64bit)
    • SUSE 12 SP2 (64bit)
    Ubuntu
    • Ubuntu 14.04 (64bit)
    • Ubuntu 16.04 (64bit)
    • Ubuntu 18.04 (64bit)
    • Ubuntu 20.04 (64-bit)
    EulerOS
    • Euler 2.2 (64bit)
    • Euler 2.3 (64bit)
    Oracle Linux
    • Oracle Linux 6.9 (64bit)
    • Oracle Linux 7.4 (64bit)
  • The following Windows OSs are supported:
    • Windows Server 2008 R2 (64bit)
    • Windows Server 2012 R2 (64bit)
    • Windows Server 2016 (64bit)
    • Windows 7 (64bit)
    • Windows 10 (64bit)
    The DBSS agent depends on Npcap. If the message "Npcap not found, please install Npcap first" is displayed when you install the DBSS agent, first install Npcap and then the DBSS agent.
    Npcap download link: https://npcap.com/#download
    Figure 1 Npcap not found
Other Constraints
  • If SSL is enabled for a database, the database cannot be audited. To use database audit, disable SSL first.
  • Ensure the VPC of the database audit instance is the same as that of the node (application side or database side) where you plan to install the database audit agent. Otherwise, the instance will be unable to connect to the agent or perform audit.
