How Do I Check the Operation Logs of Database Audit?
To check the operation logs of database audit, perform the following steps:
- Select a region, click
, and choose . The Dashboard page is displayed. - In the navigation tree on the left, choose .
- Click the name of the instance whose operation logs you want to view. The Overview page is displayed.
- Click the Logs tab. The log list page is displayed.
- View operation logs, as shown in Figure 1. For details about related parameters, see Table 1.
Select Last 30 minutes, 1 hour, 24 hours, 7 days, or 30 days, or click
to set start time and end time to view the operation logs of a specified time range.Table 1 Parameters Parameter
Username
User who performs the operation
Time
Time when the operation was performed
Function
Function of the operation
Action
Action of the operation
Operation Object
Object of the operation
Description of the operation
Result
Result of the operation
