On this page
Show all
Help Center/ Database Security Service/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Agent/ How Do I Determine Where to Install an Agent?
Updated on 2023-12-27 GMT+08:00
The database audit agent can be installed on the database, application, or proxy node (ranked in descending order of preference).
For details about the nodes, see Table 1.
Table 1 Nodes to install agents
Node
Audit Scope
Configuration
Database
Self-built database on ECS/BMS
All access records of applications that have accessed the database
Set Installing Node Type to Database.
Application
You cannot log in to the node where your database (for example, RDS database) is deployed.
Access records of all the databases connected to the application
  • Set Installing Node Type to Application, as shown in Figure 2.
  • If an agent has been installed on a database connected to the same application as the desired database, select Select an existing agent.
Proxy
You cannot log in to the node where your database (for example, RDS database) is deployed, and cannot install an agent on your application (for example, an off-cloud application).
Only the access records between the proxy and database. Those between the application and database cannot be audited.
Set Installing Node Type to Application, and set Installing Node IP Address to the IP address of the proxy.
Adding an Agent
  • Database
    Figure 1 Adding an agent to a database
  • Application
    Figure 2 Adding an agent to an application
    Figure 3 Selecting an existing agent
    NOTICE:
    If an agent has been installed on a database connected to the same application as the desired database, select Select an existing agent. For details, see When Should I Select an Existing Agent?
  • Proxy
    Figure 4 Adding an agent to an application
    NOTICE:
    Installing Node IP Address must be set to the IP address of the proxy.
