Editions
Database audit provides basic, professional, and advanced editions. You can select one of them as needed.
        Version  |
        Maximum Databases  |
        System Resource  |
        Performance  |
        Basic  |
        3  |
        Professional  |
        6  |
   - A database instance is uniquely defined by its database IP address and port.
The number of database instances equals the number of database ports. If a database IP address has N database ports, there are N database instances.
Example: A user has two database IP addresses, IP1 and IP2. IP1 has a database port. IP2 has three database ports. IP1 and IP2 have four database instances in total. To audit all of them, select professional edition DBSS, which supports a maximum of six database instances.
 - To change the edition of a DBSS instance, unsubscribe from it and apply for a new one.
 - Online SQL statements are counted based on the assumption that the capacity of an SQL statement is 1 KB.
