Viewing Audit Reports
Updated on 2023-12-27 GMT+08:00
By default, database audit complies with a full audit rule, which is used to audit all databases that are successfully connected to the database audit instance. After connecting the database to the database audit instance, generate an audit report and preview online or download it.
  • You have applied for a database audit instance and the Status is Running.
  • Database audit has been enabled.
Report Types
Database audit provides eight types of report templates. Table 1 lists the report names. You can generate reports and set report tasks as needed.
Table 1 Description
Template Name
Report Types
Database Security General Report
Overview report
Provides the overall audit status of the database, including risks, sessions, and login status to better manage databases.
Database Security Compliance Report
Compliance report
This report helps database administrators and auditors detect abnormal behaviors, locate problems, and manage information.
SOX Report
Compliance report
Complies with the Sarbanes-Oxley Act (SOX) to provide statics on and evaluate database operations. This report helps database administrators and auditors detect abnormal behaviors, locate problems, and manage information.
Database Server Analysis Report
Database report
Provides statistics and analysis on active users, user IP addresses, database logins and requests, database usage duration, and database performance.
Client IP Address Analysis Report
Client report
Provides statistics on client applications, database users, and SQL statements collected from user IP addresses.
DML Command Report
Database operation report
Analyzes user and privileged operations based on DML commands.
DDL Command Report
Analyzes user and privileged operations based on DDL commands.
DCL Command Report
Analyzes user and privileged operations based on DCL commands.
Step 1: Generating a Report
You can generate reports immediately or periodically. You can also customize the generation time, frequency, and format of reports.
  • Method 1: Generating a Report Immediately
  2. Select a region, click , and choose Security & Compliance > Database Security Service. The Dashboard page is displayed.
  3. In the navigation tree on the left, choose Reports.
  4. In the Instance drop-down list, select the instance whose instance report you want to generate.
  5. Click the Report Management tab.
  6. In the Operation column of a report template, click Generate Report.
    Figure 1 Report template list
  7. In the displayed dialog box, click to set the start time and end time of the report, and select the database for which you want to generate a report.
    Figure 2 Generate Report
  8. Click OK.
  • Method 2: Setting Periodic Report Release
  2. Select a region, click , and choose Security > Database Security Service. The Dashboard page is displayed.
  4. In the Instance drop-down list, select the instance for which you want to set a report task.
  6. Locate the target template and click Schedule Task in the Operation column, as shown in Figure 3.
    Figure 3 Setting a task
  7. In the displayed dialog box, set the parameters of the scheduled task, as shown in Figure 4. For details about related parameters, see Table 2.
    Figure 4 Setting a scheduled task
    Table 2 Parameters for setting a task
    Example Value
    Enable Task
    Status of a scheduled task.
    • : enabled
    • : disabled
    Message Notifications
    Enables or disables notifications.
    • : enabled
    • : disabled
    SMN Topic
    Select an existing topic from the drop-down list or click View Topic and create an SMN topic on the displayed page for configuring the terminals for receiving alarm notifications.
    For details about topics and subscriptions, see Simple Message Notification User Guide.
    Report Type
    Type of a report. The options are as follows:
    • Daily
    • Weekly
    • Monthly
    Weekly
    Execution Mode
    Execution mode of the report. The options are as follows:
    • Once
    • Periodically
    Periodically
    Time
    Time when the report is executed
    10:00
    Database
    Database for which you want to execute the report task
  8. Click OK.
Step 2: Previewing and Downloading Audit Reports
Before previewing or downloading an audit report, ensure that its Status is 100%.
NOTICE:
To preview a report online, use Google Chrome or Mozilla FireFox.
  4. In the Instance drop-down list, select the instance whose report you want to preview or download.
  5. Locate the target template, and click Preview or Download in the Operation column to preview or download the report. See Figure 5..
    Figure 5 Previewing or downloading an audit report
