Help Center/
      Database Security Service/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        Functions/
      What Are the Functions of Database Audit?
        Updated on 2023-01-10 GMT+08:00
  Database audit is deployed in out-of-path pattern. You can perform flexible audit on databases built on ECS, BMS, and RDS without affecting services. Database audit provides the following functions:
- Monitors database login, operation type (data definition, operation, and control), and operation object based on risky operations to effectively audit the database.
- Analyzes risks, sessions, and SQL injection to help you learn the database situation in a timely manner.
- Provides a report template library to generate daily, weekly, or monthly audit reports according to your configurations. Sends real-time alarm notifications to help you obtain audit reports in a timely manner.
   Parent topic: Functions
