Managing Database Audit Instances
After applying for a database audit instance, you can view, enable, restart, disable, or delete the instance.
- Before restarting and disabling an instance, ensure that its Status is Running.
- Before enabling or deleting an instance, ensure that its Status is Disabled.
Deleting an Instance
You can delete a database audit instance that is no longer needed. You can also delete the associated EIP at the same time.
- Click
in the upper left corner of the management console and select a region or project. - Click
and choose . The Dashboard page is displayed. - In the navigation tree on the left, choose Instances.
- In the row containing the desired instance, choose More > Delete in the Operation column.
Viewing the Instance
- Select a region, click
, and choose . The Dashboard page is displayed. - In the navigation tree on the left, choose Instances.
- View the database audit instances information. For details about related parameters, see Table 1.
Figure 1 Viewing database audit instances
- You can click the name of an instance to view its overview.
- Select an instance status from the All statuses drop-down list in the upper right corner of the list, or enter a key word of an instance to search for it.
Table 1 Parameters Parameter
Instance Name/ID
Name and ID of an instance. Instance ID is automatically generated.
Specifications
Edition of an instance
Status
Running status of an instance. The options are as follows:
- Running
- Creating
- Faulty
- Disabled
- Frozen
- Frozen for legal management
- Frozen due to abuse
- Frozen due to lack of identity verification
- Frozen for partnership
- Creation failed
Associated Databases/Total Databases
Number of databases an instance has associated with and Number of databases an instance supports
Operation
Operations can be performed on the instance. The options are as follows:
- Configure Rules
- Enable
- Disable
- Restart
- View Details
- Delete
You can perform the following operations on instances as required:
- Restart
Locate the row that contains the desired instance, choose More > Restart in the Operation column, and click OK in the displayed dialog box.
- Enable
Locate the row that contains the desired instance, choose More > Enable in the Operation column, and click OK in the displayed dialog box.
- Disable
Locate the row that contains the desired instance, choose More > Disable in the Operation column, and click OK in the displayed dialog box. When an instance is disabled, the audit function is disabled for the databases on the instance.
- Delete
Locate the row that contains the instance that failed to be created, choose More > Delete in the Operation column, and click Delete in the displayed dialog box. Deleted instances will not be displayed in the instance list.
- View Details
Locate the row that contains the instance that failed to be created, choose More > View Details in the Operation column. In the dialog box that is displayed, view the instance creation failure details.
