On this page
Help Center/ Database Security Service/ User Guide (ME-Abu Dhabi Region)/ Viewing Information About SQL Injection Detection
Updated on 2023-12-27 GMT+08:00
This section describes how to view SQL injection detection information of a database audit instance.
  • You have applied for a database audit instance and the Status is Running.
  • Database audit has been enabled.
  2. Select a region, click , and choose Security > Database Security Service. The Dashboard page is displayed.
  3. In the navigation tree, choose Audit Rules.
  4. In the Instance drop-down list, select the instance for which you want to view SQL injection detection. Click the SQL Injection tab.
  5. View information about SQL injection detection, as shown in Figure 1. For details about related parameters, see Table 1.
    Figure 1 Viewing information about the SQL injection detection
    • Select a risk severity from the All risk severities drop-down list in the upper right corner of the list, or enter a key word of an SQL injection rule name to search.
    • Click Set Priority in the Operation column of an SQL injection rule to change its priority.
    Table 1 Parameters
    Name
    Name of the SQL injection detection
    Command Feature
    Command features of the SQL injection detection
    Risk Severity
    Risk level of the SQL injection detection. The options are as follows:
    • High
    • Moderate
    • Low
    • No risks
    Status
    Status of the SQL injection detection. The options are as follows:
    • Enabled
    • Disabled
    Operation
    Operations on an SQL injection rule. The options are as follows:
    • Set Priority
    • Disable
    • Edit
    • Delete
