Help Center/
Database Security Service/
User Guide (ME-Abu Dhabi Region)/
Viewing Session Distribution
Updated on 2023-12-27 GMT+08:00
After connecting the database to the database audit instance, view session distribution of the database.
- You have applied for a database audit instance and the Status is Running.
- Database audit has been enabled.
- Select a region, click
, and choose . The Dashboard page is displayed. - In the navigation tree on the left, choose Data Reports. The Data Reports page is displayed.
- In the Instance drop-down list, select the instance whose session information you want to view.
- Click the Sessions tab.
- View the session distribution chart, as shown in Figure 1.
- Select All databases or a specified database from the Database drop-down list to view the sessions about all databases in the instance or a specified database.
- Select Last 30 minutes, 1 hour, 24 hours, 7 days, or 30 days, or click
to set start time and end time to view the sessions of the specified time range.
