Step 2: Add an Agent
Add a new agent or choose an existing agent for the database to be audited, depending on your database type. The agent will obtain database access traffic, upload traffic statistics to the audit system, receive audit system configuration commands, and report database monitoring data.
After adding an agent, configure TCP (port 8000) and UDP (ports 7000 to 7100) in the security group inbound rule of the agent node to allow the agent to communicate with the audit instance.
Currently, only the following types of databases support agent-free audit:
- GaussDB for MySQL
- RDS for SQLServer
- RDS for MySQL
- 5.6 (5.6.51.1 or later)
- 5.7 (5.7.29.2 or later)
- 8.0 (8.0.20.3 or later)
- You have applied for a database audit instance and the Status is Running.
- A database has been added.
Determine where to add the agent based on how your database is deployed. Common database deployment modes are as follows:
- Deploy DBSS for databases built on ECS/BMS. For details, see Figure 1 and Figure 2.
- Deploy DBSS for RDS databases. For details, see Figure 3 and Figure 4.
Table 1 provides more details.
- If your applications and databases (databases built on ECS/BMS) are deployed on the same node, add the agent on the database side.
Scenario |
Where to Add the Agent |
Audit Scope |
Description |
Databases built on ECS/BMS |
Database |
All access records of applications that have accessed the database |
RDS database |
Application (if applications are deployed on the cloud) |
Access records of all the databases connected to the application |
Proxy side (if applications are deployed off the cloud) |
Only the access records between the proxy and database. Those between the applications and database cannot be audited. |
Adding an Agent (Self-built Databases on ECS/BMS)
- Select a region, click
, and choose . The Dashboard page is displayed. - In the navigation tree on the left, choose Databases.
- In the Instance drop-down list, select the instance whose agent is to be added.
- In the Agent column of the desired database, click Add.
- In the dialog box displayed, select an add mode, as shown in Figure 5. For details about related parameters, see Table 2.
Table 2 Parameters for adding an agent (databases built on ECS/BMS) Parameter
Example Value
Add Mode
Mode for adding an agent- Select an existing agent
If an agent has been installed on a database connected to the same application as the desired database, select Select an existing agent.
- Create an agent
If no agent is available, select Create an agent to create one.
Create an agent
Installing Node Type
This parameter is mandatory when Add Mode is set to Create an agent.
When auditing user-installed databases on ECS/BMS, select Database for Installing Node Type.
Database
OS
OS of the database to be audited. Its value can be .
You can select LINUX64-X86, LINUX64-ARM, or WINDOWS64.
NOTE:Select LINUX64_X86 or LINUX64_ARM based on the server architecture.
LINUX64-X86
- Click OK.
- Click
in the lower part of the database list page to expand the database details and view the information about the added agent.
Figure 6 Successfully adding an agent
After adding the agent, confirm that the agent information is correct. If the agent is incorrectly added, locate the target agent, click More > Delete in the Operation column, and add an agent again.
Adding an Agent (RDS Databases)
After you add a MySQL or GaussDB(for MySQL) database, you can start configuring security group rules. You do not need to install an agent on the database.
If an application connects to multiple RDS databases, be sure to:
- Add an agent to each of the RDS databases.
- Select Select an existing agent if one of the databases already has an agent. Add that agent for the rest of the databases.
- In the displayed dialog box, select an add mode, as shown in Figure 7 and Figure 8. For details about related parameters, see Table 3.
- Select Select an existing agent for Add Mode.
- Set Add Mode to Create an agent.
Table 3 Parameters for adding an agent (RDS databases) Parameter
Example Value
Add Mode
Mode for adding an agent- Selecting an existing agent
- Create an agent
Create an agent
To audit the RDS databases, select Application.
Application
Installing Node IP Address
This parameter is mandatory if Installing Node Type is set to Application. You can enter only one installation node IP address. The IP address of an agent must be unique.
The IP address is the intranet IP address of the application.
The IP address must be an internal IP address in IPv4 or IPv6 format.
NOTICE:To audit an RDS database connected to an off-cloud application, set this parameter to the IP address of the proxy.
192.168.1.1
Audited NIC Name
Optional. This parameter is configurable if Installing Node Type is set to Application.
Name of the network interface card (NIC) of the application node to be audited
CPU Threshold (%)
CPU threshold of the application node to be audited. The default value is 80.
NOTICE:If the CPU usage of a server exceeds the threshold, the agent on the server will stop running.
80
Memory Threshold (%)
Memory threshold of the application node to be audited. The default value is 80.
NOTICE:If the memory usage of your server exceeds the threshold, the agent will stop running.
80
OS
OS of the application node to be audited. The value can be LINUX64 or WINDOWS64.
LINUX64
- Click OK.
- Click
next to the database to view its details and information about the added agent.
Figure 9 Successfully adding an agent
Follow-Up Procedure
After adding an agent, install the agent on the database or application based on the add mode you chose. Database audit works only when the database to be audited is connected to the database audit instance. For details about how to install an agent, see Installing an Agent.
