- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Overview
- Enabling and Using Database Audit (by Installing Agents)
- Enabling and Using Database Audit (Without Installing Agents)
- Upgrading the Database Audit Instance Version
- Configuring Audit Rules
- Viewing Audit Results
- Notification Settings Management
- Viewing Monitoring Information
- Backing Up and Restoring Database Audit Logs
Other Operations
- Managing Database Audit Instances
- Viewing the Instance Overview
- Managing Databases and Agents
- Uninstalling an Agent
- Management an Audit Scope
- Viewing Information About SQL Injection Detection
- Managing Risky Operations
- Managing Privacy Data Protection Rules
- Managing Audit Reports
- Managing Backup Audit Logs
- Viewing Operation Logs
- Key Operations Recorded by CTS
- Monitoring
- Shared VPC
- Permission Control
Best Practices
- Auditing a User-built Database on ECS
- Auditing an RDS DB instance (with Agents)
- Auditing an RDS DB Instance (Without Agents)
- Deploying the Database Audit Agent in a Container
- Checking for Slow SQL Statements
- Checking for Data Reduction
- Checking for Dirty Tables
- Configuring Oracle RAC Cluster Audit
- Meeting Database Audit Compliance Requirements
- Configuring Database Audit Instance Rules
- Change History
API Reference
- Before You Start
- Calling APIs
API
- Querying on the Management Side
Audit Instance
- Deleting an Audit Instance
- Creating an Audit Instance in Yearly/Monthly Billing Mode
- Querying Information About an Instance Creation Task
- Querying the Audit Instance List
- Changing a Security Group
- Starting an Audit Instance
- Stopping an Audit Instance
- Restarting an Audit Instance
- Updating Audit Instance Information
- Auditing a Database
- Auditing Agent
- Data Analytics
- Audit Rules
- TMS Tags
- Adding an RDS Database (Deprecated)
- Appendix
Product Consulting
- What Is Database Audit?
- What Are the Differences Between DBSS Database Audit and RDS SQL Audit?
- What Editions Does DBSS Provide?
- What Databases on Huawei Cloud Does DBSS Protect?
- What Databases Does DBSS Support?
- Why Can't I See the Instance that Is Being Created After I Purchased It?
- Will My Services Be Affected If I Do Not Renew DBSS After It Expires?
- Does Database Audit Support On-premises or Non-Huawei Cloud Databases?
- What Are Regions and AZs?
- Does DBSS Support Real-Time Data Masking?
- Can DBSS Audit Databases Across Subnets?
- Is There Any Restriction on the Gateway IP Address of DBSS Audit Instances?
Purchase
- Which Subnet Should I Choose When Purchasing an Instance?
- Why Do I Need to Select a VPC When Buying an Instance?
- How Many Database Audit Instances Can I Purchase in the Same Region?
- What Do I Do If a Message Indicating Insufficient Quota Is Displayed During Instance Purchase?
- How Do I Renew Database Audit?
- How Do I Unsubscribe from DBSS?
Functions
- Can Database Audit Be Used Across AZs?
- Does Database Audit (in Bypass Mode) Affect My Services?
- Is the Database Audit Function Available to Users Other Than the Buyer?
- What Are the Functions of Database Audit?
- Supported Database Types
- What OSs Can I Install the Database Audit Agent On?
- Does Database Audit Support Bidirectional Audit?
- Can I Audit Databases Across Different VPCs?
- Can Applications Using TLS Connections Be Audited?
- How Long Is the Database Audit Data Stored by Default?
- How Soon Can I Receive an Alarm Notification If an Exception Occurs in Database Audit?
- Is the Total Number Of Alarms Every Day the Same as that of Emails?
- Why I Cannot Preview the Database Security Audit Report Online?
- If I Use Middleware at the Service Side, Will It Affect Database Audit?
- Can DBSS Capture SQL Statements Executed by Third-Party Tools?
- Can DBSS Be Deployed Off the Cloud?
- Can I Change the VPC of a DBSS Instance?
- How Do I Interconnect with DBSS Audit Data Storage?
- What Should I Do If an Alarm of Insufficient DBSS Capacity Is Displayed?
Agent
- Which Functions Do the Database Audit Agent Provide?
- On What Windows Versions Can I Install the Agent?
- On What Linux OSs Can I Install the Agent?
- What Is the Process Name of the Database Audit Agent?
- (Linux OS) What Should I Do If I Lack the Permission to Run the Agent Installation Script?
- (Linux OS) Where Are the Logs of the Database Audit Agent Saved?
- When Should I Select an Existing Agent?
- What Do I Do If the Database Audit Agent Is Hibernating?
- How Do I Deploy the Agent If I Have an RDS Database That Connects to Multiple ECSs?
- How Do I Determine Where to Install an Agent?
- How Do I Run a Database Audit Agent?
- How Do I Check the Status of the Database Audit Agent?
- How Do I Download a Database Audit Agent?
- How Do I Uninstall a Database Audit Agent?
- Can I Modify the CPU and Memory Thresholds of the Agent?
- How Do I Install the Agent (in Linux OS)?
- How Do I Install the Agent (in Windows OS)?
- What Do I Do If the Communication Between the Agent and Database Audit Instance Is Abnormal?
- How Many Resources Are Consumed by an Agent When It Runs on a Node?
- What Do I Do If Agent Installation Fails?
- What Do I Do If the Error Message "unsupport this Linux version, please check your Linux version with install document!" Is Displayed During Agent Installation?
Operations
- How Do I Configure Database Audit?
- How Do I Disable SSL for a Database?
- How Do I Set the INSERT Audit Policy for Database Audit?
- How Do I Verify My Database Audit Configuration?
- How Do I Set Database Audit Rules for All Databases?
- How Do I Check the Version of Database Audit?
- How Do I View All Alarms in Database Audit?
- How Do I Audit an RDS Database Accessed through Intranet (by Applications Off the Cloud)?
- How Do I Add an HBase Database and Perform Audit?
Troubleshooting
- Database Audit Is Running Properly But Generates No Audit Records
- Database Audit Is Unavailable
- Alarm Notifications Are Abnormal
- Why I Failed to Access the DBSS Purchase Page?
- What Do I Do If I Audit RDS Psostgres Database but No Audit Result Is Displayed?
- DBSS Automatic Backup Failed and The Failure Code is "Export backup file failed"
Logs
- Can the Operation Logs of Database Audit Be Migrated?
- How Long Are the Operation Logs of Database Audit Saved by Default?
- How Do I Check the Operation Logs of Database Audit?
- How Does Database Audit Process Logs?
- How Do I Back Up the Database Audit Logs?
- Can Database Audit Logs Be Directly Saved to OBS?
- Backup Gets Stuck at the Backup File Uploading Phase
- Change History
Product Consulting
- Videos
More Documents
- Overview
- Process Overview
- Applying for a Database Audit Instance
- Step 1: Add a Database
- Step 2: Add an Agent
- Step 3: Download and Install the Agent
- Step 4: Add a Security Group Rule
- Step 5: Enable Database Audit
- Adding Audit Scope
- Enabling or Disabling SQL Injection Detection
- Adding Risky Operations
- Configuring Privacy Data Protection Rules
- Viewing SQL Statement Details
- Viewing Session Distribution
- Viewing the Audit Dashboard
- Viewing Audit Reports
- Configuring Alarm Notifications
- Viewing the System Monitoring
- Viewing the Alarms
- Viewing Tracing Logs
- Auditable Operations
- Product Consulting
Functions
Agent
- Operations
- Troubleshooting
Logs
- Change History
- Overview
- Quick Start
- Step 3: Add a Security Group Rule
- Step 4: Download and Install the Agent
- Step 6: View Audit Results
Other Operations
Functions
Agent
- Operations
- Troubleshooting
Logs
- Change History
User Guide (Paris and Amsterdam Regions)
- Overview
Functions
Agent
- Operations
- Troubleshooting
- Logs
Functions
- Change History
- API Reference (Paris and Amsterdam Regions)
Show all
Database audit supports databases built on ECS, BMS, and RDS on the console. After applying for a database audit instance, you need to add the database to be audited to the instance.
You have applied for a database audit instance and the Status is Running.
Adding a Database
- Select a region, click
, and choose Security > Database Security Service. The Dashboard page is displayed.
- In the navigation tree on the left, choose Databases.
- In the Instance drop-down list, select the instance whose database is to be added.
- Click Add Database.
- In the dialog box displayed, set the database information, as shown in Figure 1.
Table 1 Parameters Parameter
Example Value
Name
Custom name of the database to be added
test1
IP Address
IP address of the database to be added.
The IP address must be an internal IP address in IPv4 or IPv6 format.
IPv4: 192.168.1.1
IPv6: fe80:0000:0000:0000:0000:0000:0000:0000
Type
Supported database type. The options are as follows:- MYSQL
- ORACLE
- POSTGRESQL
- SQLSERVER
- DWS
- TAURUS
- GaussDB
- DAMENG
- KINGBASE
- SHENTONG
- GBase 8a
- GBase XDM Cluster
- Greenplum
- HighGo
- Mariadb
If ORACLE is selected, to make the audit settings take effect, restart the applications to be audited and log in to the database again.
MYSQL
Port
Port number of the database to be added
3306
Version
Supported database versions
- When Type is set to MYSQL, the following versions are available:
- When Type is set to ORACLE, the following versions are available:
- 11g
- 12c
- 19c
- When Type is set to POSTGRESQL, the following versions are available:
- When Type is set to SQLSERVER, the following versions are available:
- 2008
- 2012
- 2014
- 2016
- 2017
- When Type is set to DWS, the following versions are available:
- 1.5
- When Type is set to TAURUS, the following versions are available:
- MySQL 8.0
- When Type is set to GaussDB, the following version is available:
- 1.4 Enterprise Edition
- When Type is set to DAMENG, the following version is available:
- DM8
- When Type is set to KINGBASE, the following version is available:
- V8
5.0
Instance
Instance name of the database to be audited
- If you do not configure the Instance field, database audit will audit all instances in the database.
- If you enter an instance name, database audit will audit the entered instance. Enter a maximum of five instance names and use semicolons (;) to separate instance names.
Character Set
Encoding format of the database character set. The options are as follows:
- UTF-8
- GBK
UTF-8
OS
OS of the added database. The options are as follows:- LINUX64
LINUX64
Database Type
Type of the database to be added. Its value can be RDS database or Self-built database.
RDS database
- Click OK. Then a database in the Disabled state has been added to the database list. See Figure 2.
- After adding the database, confirm that the database information is correct. If the database information is incorrect, locate the target database and click Delete in the Operation column, and add the database again.
