Related Services
ECS
DBSS instances are created on ECSs. You can use the DBSS instances to audit databases built on ECS.
RDS
DBSS can audit RDS instances.
BMS
DBSS can audit databases built on BMSs.
CTS
Cloud Trace Service (CTS) provides you with a history of DBSS operations. After enabling CTS, you can view all generated traces to review and audit performed DBSS operations. For details, see the Cloud Trace Service User Guide.
Operation |
Resource Type |
Trace Name |
Creating an instance |
dbss |
createInstance |
Deleting an Instance |
dbss |
deleteInstance |
Starting an Instance |
dbss |
startInstance |
Stopping an Instance |
dbss |
stopInstance |
Restarting an Instance |
dbss |
rebootInstance |
OBS
Object Storage Service (OBS) is an object-based cloud storage service. It provides massive, secure, highly reliable, and low-cost data storage capabilities. Database audit logs can be backed up to OBS buckets to achieve high availability for disaster recovery.
IAM
Identity and Access Management (IAM) provides you with permission management for DBSS.
Only users who have the DBSS System Administrator permissions can use DBSS.
To obtain the permissions, contact users who have the Security Administrator permissions. For details, see the Identity and Access Management User Guide.
