CCE.NodePool
Element Description
The CCE.NodePool element is used to deploy Kubernetes node resources at the PaaS layer. You can use it to orchestrate cloud resources on nodes.
Element Properties
Property |
Mandatory |
Description |
dataVolumes |
Yes |
Data disk of a created node Type: CCE.DataVolume array Value Description: Customize the value, for example, [{"volumeType":"SATA","size":100}]. Value Constraint: Array format. Currently, only one object is supported. Suggestion: Customize the value. |
availabilityZone |
Yes |
AZ where a node is located Type: Cloud.ECS.AvailabilityZone.Name Value Description: AZ where the to-be-created ECS is located. The name of the AZ needs to be specified, for example, ae-ad-1a. For details, see the Regions and Endpoints page. Value Constraint: The value varies depending on regions. Suggestion: Use the get_input function to set this field, and then the value can be automatically selected on the AOS console. |
name |
Yes |
Name of the created node Type: string Value Description: Customize the value. Value Constraint: The value contains 4 to 32 characters and must start with a lowercase letter. Only lowercase letters, digits, and underscores (_) are allowed. Suggestion: Customize the value. Generally, the stack name is used as the node name. |
publicKey |
No |
Public key of the key pair. If the node pool is billed in the yearly/month mode, this parameter is mandatory. Type: Cloud.ECS.KeyPair.PublicKey Value Description: Selects an existing public key. Suggestion: Use the get_input function to set this field, and then the value can be automatically selected on the AOS console based on the value of sshKeyName. |
postInstall |
No |
Node post-installation script Type: string Value Description: Customize the value. Value Constraint: The script you specify here will be executed after K8S software is installed. Suggestion: The script is usually used to modify Docker parameters. |
labels |
No |
Node label Type: CCE.Labels array Value Description: Customize the value, for example, {"app": "aos"}. Suggestion: You can enter multiple key-value pairs. |
clusterId |
No |
ID of the cluster to which the resource belongs Type: Cloud.CCE.Cluster.Id Value Description: ID of an existing or new container cluster. Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters. Suggestion: 1. Enter the cluster ID. Specifically, log in to the CCE console, and choose Resource Management > Clusters. Click the target cluster, and you can then obtain its cluster ID. 2. Connect to the cluster object and use the get_reference function to obtain the cluster ID. |
preInstall |
No |
Node pre-installation script Type: string Value Description: Customize the value. Value Constraint: The script you specify here will be executed before K8S software is installed. Note that if the script is incorrect, K8S software may not be installed successfully. Suggestion: The script is usually used to format data disks. |
publicIp |
No |
Virtual IP address of the created node Type: CCE.PublicIP Value Description: Customize the value, for example, {"eip":{"bandwidth:{"shareType":PER}, 5_sbgp"}}. Default: {} Value Constraint: Only one elastic IP address can be defined for each node. Suggestion: Customize the value. |
instances |
Yes |
Number of created nodes Type: integer Value Description: Customize the value. The value ranges from 1 to 50. Default: 1 Value Constraint: {u'in_range': [1, 50]} Suggestion: Set the value based on the live environment. |
rootVolume |
Yes |
System disk of the created node Type: ECS.RootVolume Value Description: Customize the value, for example, {"volumeType":"SATA","size":40}. Default: {u'volumeType': u'unset', u'size': 40} Suggestion: Customize the value. |
os |
No |
Node OS Type: string Value Description: ["EulerOS 2.2", "CentOS 7.4"] Default: EulerOS 2.2 Value Constraint: {u'valid_values': [u'CentOS 7.4', u'EulerOS 2.2']} |
nodePasswd |
No |
Password of the node root user Type: password Value Description: Customize the value. Value Constraint: 1. The parameter must be written into inputs and set using the get_input function. 2. The value must not be a weak password. Enter 8 to 26 characters. Only uppercase and lowercase letters, digits, and special characters !@$%^-_=+[{}]:,./? are allowed. The value must contain at least two types of characters. Suggestion: You are advised to use the get_input function to obtain the value and avoid plaintext passwords to ensure security. |
flavor |
Yes |
Container node specification Type: Cloud.CCE.Node.Flavor.Name Value Description: ID of the system flavor of the cloud server to be created. For details about the available flavors, see Elastic Cloud Server Service Overview. It is advised to use the get_input function to pass this parameter. Suggestion: Select the node specification during node creation on the CCE console. In the node template, you can set the inputs to specify the node specification. |
sshKeyName |
No |
Key pair used for logging in to a node, which needs to be kept properly Type: Cloud.ECS.KeyPair.Name Value Description: It must be created on the ECS console in advance. Suggestion: 1. You are advised to use the get_input function to set the parameter so that you can select a value when using the template. 2. Search for the information on the ECS console, and enter the information accordingly. |
annotations |
No |
Node annotations Type: dict Value Description: Customize the value, for example, {"app": "aos"}. Suggestion: You can enter multiple key-value pairs. |
Relationships Between Elements
Description |
Target |
Inclusion |
Connected |
Connected |
Connected |
Connected |
Connected |
Return Value
Property |
Type |
Description |
floatingIpId |
string |
ID of an elastic IP address |
clusterId |
string |
Cluster ID |
refName |
string |
Node name |
privateIp |
Array |
List of private elastic IP addresses |
publicIp |
Array |
List of public elastic IP addresses |
refID |
string |
Node ID |
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0 node_templates: ccenp1ep: type: Cloud.CCE.NodePool properties: dataVolumes: - volumeType: SATA size: 100 name: '' instances: 1 rootVolume: volumeType: SATA size: 40 flavor: get_input: ccenp1ep_flavor sshKeyName: get_input: ccenp1ep_sshKeyName inputs: ccenp1ep_flavor: description: Container node specifications label: '' ccenp1ep_sshKeyName: description: Key pair used for logging in to a node. Keep the key pair properly. label: ''
