- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
CCE.Storage.OBS
Element Description
The CCE.Storage.OBS element corresponds to object storage volumes in the CCE storage management function. This type of resources must be used together with CCE clusters.
Element Properties
Property |
Mandatory |
Descripiton |
k8sManifest |
No |
K8s-native manifest object of the OBS, which can be used to replace other configuration items in OBS resource creation Type: dict Value Constraint: The value must meet the Kubernetes specifications. Suggestion: For details, see the sample or CCE documentation. |
name |
No |
PVC name Type: string Value Description: Customize the value. Value Constraint: Each PVC name must be unique in a namespace. The value must contain 1 to 24 characters and meet regular expression (^$)|(^[a-z]([-a-z0-9]*[a-z0-9])?$). Suggestion: Customize the value. |
clusterId |
No |
ID of the cluster to which the resource belongs Type: Cloud.CCE.Cluster.Id Value Description: ID of an existing or new container cluster. Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters. Suggestion: 1. Enter the cluster ID. Specifically, log in to the CCE console, and choose Resource Management > Clusters. Click the target cluster, and you can then obtain its cluster ID. 2. Connect to the cluster object and use the get_reference function to obtain the cluster ID. 3. Leave it blank, and specify the ID on the AOS console when creating a stack. |
namespace |
No |
Namespace to which the resource belongs Type: string Value Description: It must be a valid namespace in the cluster, for example, default. Value Constraint: The value must start with a letter. Only lowercase letters, digits, and hyphens (-) are allowed. Suggestion: Customize the value based on the existing cluster or the cluster to be created. |
volumeId |
No |
Cloud storage volume ID when you import a volume Type: string Value Description: Customize the value. Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters. Suggestion: None |
deleteVolume |
No |
Whether to delete the cloud storage when you import a volume and delete a PVC Type: boolean Default: False Value Constraint: The options are true and false. Suggestion: None |
Relationships Between Elements
Description |
Target |
Dependency |
Dependency |
Dependency |
Dependency |
Dependency |
Dependency |
Dependency |
Inclusion |
Return Value
Property |
Type |
Description |
clusterId |
string |
ID of the cluster which is associated with the OBS file system |
refID |
string |
UID of the OBS file system |
refName |
string |
Name of the OBS file system |
Blueprint Example
Example 1:
tosca_definitions_version: cloud_tosca_version_1_0 inputs: storage-name: default: my-evc-storage node_templates: my-storage: type: Cloud.CCE.Storage.OBS properties: name: {get_input: storage-name}
Example 2: Custom K8s Manifest for Orchestration
- For clusters of version 1.13 or earlier, the example configuration of the YAML file is as follows:
tosca_definitions_version: cloud_tosca_version_1_0 node_templates: my-storage: type: Cloud.CCE.Storage.OBS properties: apiVersion: v1 kind: PersistentVolumeClaim metadata: annotations: volume.beta.kubernetes.io/storage-class: obs-standard volume.beta.kubernetes.io/storage-provisioner: flexvolume.com/obs name: cce-obs-k7yhr36u-iuu9 namespace: default spec: accessModes: - ReadWriteMany resources: requests: storage: 10Gi
