CCE.HelmRelease
Element Description
Helm is a type of Kubernetes-based package specifications provided by CCE. The CCE.HelmRelease element is a deployment instance of the Helm package.
Element Properties
Table 1 Property Description
Property
Mandatory
Descripiton
name
Yes
Name of the created CCE.HelmRelease
Type: string
Value Description: Customize the value, for example, my_release.
Value Constraint: The value must start with a letter. Only lowercase letters, digits, and hyphens (-) are allowed.
clusterId
No
ID of the cluster to which the resource belongs
Type: Cloud.CCE.Cluster.Id
Value Description: ID of an existing or new container cluster.
Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters.
Suggestion: This parameter is optional. You can set this parameter when creating a stack.
namespace
No
Namespace where the resource is located
Type: string
Value Description: namespace of a cluster
Default: default
chart
Yes
Chart information about the Helm application
Type: CCE.HelmChart
Value Description: Information includes the chart package name and version number, which can be obtained from Charts in the navigation pane on the CCE console.
Default: {u'version': u'', u'name': u''}
Suggestion: Set the value based on the helm application to be orchestrated.
values
Yes
Input value of the Helm application
Type: dict
Value Description: Customize the value.
Default: {}
Value Constraint: Composite structure, which is similar to {"key": "value"}, where value can be nested.
Suggestion: For your own applications, enter the corresponding value.
Relationships Between Elements
Table 2 Relationship description
Target
Connected
CCE.Pod
Connected
CCE.Storage.SFS
Connected
CCE.HelmRelease
Connected
CCE.Storage.OBS
Inclusion
CCE.Cluster
Return Value
Property
Type
clusterId
string
Cluster ID
refName
string
Release name
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0
inputs:
  release_name:
    default: "release"
  cluster_id:
    default: "25f511bc-00f7-11e8-958d-0255ac101a5a"
  namespace:
    default: "default"
  chart_name:
    default: "redis"
  chart_version:
    default: "1.0.0"
  app_image:
    default: "10.125.5.235:20202/test/redis:3.2.8"
  config_image:
    default: "10.125.5.235:20202/test/redis-conf:3.2.8"
  service_port:
    type: integer
    default: 6379
node_templates:
  redis-helm:
    type: Cloud.CCE.HelmRelease
    properties:
      name: {get_input: release_name}
      chart:
        name: {get_input: chart_name}
        version: {get_input: chart_version}
      clusterId: {get_input: cluster_id}
      namespace: {get_input: namespace}
      values:
        chartimage:
          app_image: {get_input: app_image}
          config_image: {get_input: config_image}
        format1:
          redis_master_replicas: 1
          redis_sentinel_replicas: 1
          redis_slave_replicas: 1
        format2:
          redis_slave_replicas: 2
        highavailable:
          redis_replication_enabled: true
        servicestorage:
          service:
            instance: "127.0.0.1"
            service_port: {get_input: service_port}
            type: "ClusterIP"
          storage:
            enabled: false
            kind: "sas"
