Overview
Huawei Cloud provides various network services for you to set up secure and scalable cloud networks. With these network services, you can connect VPCs in the same region or different regions, enable the instances (such as ECSs and RDS instances) in VPCs to access the public network, and enable on-premises data centers to access the VPCs. The following describes the function and highlights of each network service. You can flexibly configure VPC and other network services based on your network requirements:
Connecting VPCs
| Networking Service | Function | Highlights |
| With VPC Peering, you can peer two VPCs in the same region. The VPCs can be in the same account or different accounts. |
| An enterprise router can connect multiple VPCs in the same account or different accounts to set up a hub-and-spoke network. Compared with VPC Peering, Enterprise Router is more suitable for complex networking where many VPCs need to be connected. |
| Cloud Connect | Cloud Connect can connect VPCs under the same account or different accounts across regions. Cloud Connect provides two options:
| You can use VPN to connect VPCs in different regions. This will enable them to communicate with each other over the Internet. |
| You can use Direct Connect to connect VPCs in different regions. |
Connecting VPCs to the Public Network
| An EIP is an independent public IP address. You can bind it to an instance, such as an ECS, a NAT gateway, or a load balancer, so that the instance can access the Internet or provide services accessible from the Internet. |
| NAT Gateway supports both source NAT (SNAT) and destination NAT (DNAT).
| ELB evenly distributes incoming traffic to multiple backend servers. Together with EIPs, ELB allows a large number of users to access services deployed on cloud servers from the Internet. |
Connecting VPCs to an On-Premises Data Center
If you have an on-premises data center and not all your workloads can be migrated to the cloud, you can use the network services described in Table 3 to connect your on-premises data center to the VPCs.
| VPN provides an encrypted, Internet-based channel that connects an on-premises data center and the cloud. |
| Direct Connect establishes a dedicated network connection between an on-premises data center and the cloud. |
| With VPC Peering, you can peer two VPCs in the same region, no matter whether they are in the same account or different accounts. VPC Peering can work with Direct Connect or VPN to enable your on-premises data center to access multiple VPCs. |
| You can use VPN or Direct Connect to connect an on-premises data center to a VPC, and then use an enterprise router to connect multiple VPCs if they are in the same region. |
| Cloud Connect | You can use Direct Connect or VPN to connect on-premises data centers to VPCs in multiple regions and use a cloud connection or central network to connect the VPCs, so that the on-premises data centers can communicate with all the VPCs. By working with Direct Connect, Cloud Connect provides the following two options:
