Updated on 2025-01-22 GMT+08:00
env
Use env to define environment variables as key-value pairs. Environment variables can be referenced in any job within the pipeline.
Example
env:
  version: 1.0.0
You can use ${version} or ${{ env.version }} to reference the variable in any job.
${{ env.version }} is recommended, as shown in the example. For more information about the expression syntax, see Configuring Expressions.
