Checking a Pipeline
You can check the pipeline list, pipeline execution history, execution details, and queuing status.
Notes and Constraints
By default, only project managers, project creators, and pipeline creators can delete pipelines. You can configure permissions for different roles.
Checking a Pipeline
- Access the CodeArts Pipeline homepage.
The pipeline list page displays all pipelines of the current user. The information is listed in the following table.
Table 1 Pipeline information Parameter
Name
Pipeline name and the project to which the pipeline belongs.
If you access CodeArts Pipeline through a project, the project name will not be displayed here.
Last Executed
Information about the most recently executed pipeline, including the execution mode, branch, latest code commit ID, and executor.
Workflow
Scheduling process and execution status (completed, failed, running, or stopped) of the pipeline.
Started & Lasted
Start time and duration of the last execution.
Operation
- Click
to execute the pipeline.
- Click
to favorite a pipeline. After the pipeline is favorited, the icon changes to
. You can click the icon again to unfavorite the pipeline.
After you favorite a pipeline, the pipeline will be displayed on top of the pipeline list when you access the page again. Favorited pipelines are sorted in descending order based on their last execution time. If they have not been executed, they are sorted in descending order based on their creation time.
- Click
and select Edit to edit a pipeline.
- Click
and select Clone to quickly create a pipeline based on the current pipeline.
- Click
and select Preview to preview a pipeline.
- Click
and select Operation History to view historical operation records (creation, editing, and failure).
- Click
and select Set Tag. In the displayed dialog box, perform the following operations.
- Click
to add tags for the pipeline. Max. five tags for each pipeline.
- Click Manage Tags to create, edit, or delete tags.
A tenant can create a maximum of 100 tags.
- Click
- Click
and select Disable to disable a pipeline.
- Click
and select Delete to delete a pipeline.
- By default, all users can view the pipeline list.
- Click the drop-down list box of All Pipelines to filter pipelines by All pipelines, My created pipelines, or My executed pipelines.
- You can search for a pipeline by its name.
- Click Set in the upper right corner to customize the pipeline display information.
- Click
- Click a pipeline name, the Execution History page is displayed, showing the execution records.
Execution records are generated only after the first execution.
Table 2 Execution history Parameter
Execution Message
Displays the execution sequence number, execution branch, latest commit information, and latest commit ID of the branch.
Status
Pipeline execution status, including completed, running, failed, stopped, paused, suspended, and ignored.
Execution Type
Pipeline triggers, including manually, scheduled task, MR, push, webhook, and sub-pipeline.
Workflow
Execution Time
Time when the pipeline starts to be executed.
Execution Duration
Duration of the pipeline execution.
- You can click the time filter to filter execution records by time. By default, executions in the past 31 days are displayed. You can also check executions in the past 7 days, 14 days, or 90 days.
- Click Set in the upper right corner to customize the pipeline execution history information.
- Click the execution ID to go to the Pipeline Details page and check the execution details.
Table 3 Operations on the pipeline details page Operation
Retry
If the execution fails, you can click Retry in the upper right corner to continue the execution.
Edit
You can click Edit to orchestrate the pipeline.
Execute
You can click Execute to execute the pipeline with the latest configurations. An execution record will be generated.
Download
You can click Download next to Output to download the build packages.
- Build packages are available only for build jobs.
- If there are multiple build packages, click Download All.
- Only the latest 10 build packages are displayed. To download other build packages, go to the Release Repos page.
View logs
Click a job card to check its logs and result.
- No log will be generated for jobs of DelayedExecution and PipelineSuspension.
- You can click the failed job card to check the failing reason.
More operations
Click
in the upper right corner of the page to clone, preview, disable, and delete the pipeline, and check the operation history.
- Click the Queued tab.
This page displays the instances to be executed.
- Max. 100 queuing instances per pipeline.
- Instances will not be executed after 24 hours of waiting.
- Click
in the Operation column to cancel the queuing.
- Instance configurations are fixed once they enter the queue.
