Updated on 2026-04-23 GMT+08:00
Sharing a Folder
You can share your folders in OBS with others.
Folder can be shared temporarily or permanently.
Background Information
  • Temporary sharing:
    Share a folder to other users through the temporary URL of the file. Folder sharing is temporary. All shared URLs are only valid for a limited period of time.
    Folders can be temporarily shared by access code or URL:
    Sharing by access code
    You need to specify a six-digit access code before creating a sharing task. After the sharing task is created, OBS aggregates the download links of all objects in the folder to a static website that is hosted by a public OBS bucket. Then anyone who has the created temporary URL and access code can access the static website and download the shared files.
    A temporary URL consists of the access domain name and the temporary authentication information of a folder. Example:
    https://e-share.obs-website.ap-southeast-1.myhuaweicloud.com:443/image.png?token=xxx
    For details about temporary authentication and its parameters, see Using a Pre-Signed URL in the Object Storage Service API Reference.
    Sharing by URL
    You can specify a validity period and then share the generated link with others. Anyone can use a signature to access all objects in the shared folder.
    A temporary URL for accessing an object in a folder consists of a bucket domain name (prefix), an object path, and signature information (suffix).
  • Permanent sharing:
    If you set the permission for an object to allow anonymous users to read it, anonymous users can access the object through the URL that you shared. For details about how to configure permissions, see Granting All Accounts the Read Permission for Certain Objects.
    For details about how to obtain the object access URL, see How Do I Obtain the Access Path to an Object?
    If access to an object using the URL fails, fix the problem by referring to Why Can't I Access an Object Through Its URL?
  • The following table describes the URL validity period of the folders that are temporarily shared in different ways.
    Way
    URL Validity Period
    OBS Console
    The URL is valid for 1 minute to 18 hours.
    When you click the Share button for a folder, OBS retrieves temporary authentication information with a default validity of 5 minutes and creates a sharing link. Each time you change the validity period of a URL, OBS obtains the authentication information again to create a new shared URL. This new URL is in effect immediately upon the change.
    If you need a longer validity period, you can use OBS Browser+ to set a validity period of up to one year. If you want a shared object to be permanently valid, use a bucket policy to grant anonymous users the public read permission for the folder.
    APIs
    Configure parameter Expires to specify when a temporary authorization expires. The temporary authorization expires in 24 hours.
    OBS Browser+
    When you log in to OBS Browser+ using an account and password, a shared URL can be valid for 24 hours at most. The default validity period is 10 hours.
    If a longer validity period is required, use the permanent AK/SK for login.
    obsutil
    Use the additional parameter vp to specify how long an authorization code is valid. The default validity period is one day. The allowed units include m (months), w (weeks), d (days), h (hours), min (minutes), and s (seconds). If no time unit is specified, the value is calculated in seconds.
  • Folder sharing is restricted to a few regions only.
  • Only buckets whose version is 3.0 support folder sharing. For details about how to query the bucket version, see Checking OBS Version (OBS 2.0 or OBS 3.0).
  • Archive objects in a folder must be restored in the bucket before they can be downloaded.
  • Deep Archive objects in a folder must be restored in the bucket before they can be downloaded.
Ways to Share a Folder
You can use OBS Browser+, obsutil, or OBS Console to share a folder.
