Task Center
When you upload objects, restore objects in batches, change storage classes in batches, or delete folders, corresponding records of the tasks will be displayed in the task center for you to view the tasks' progress and status.
When the web page is reloaded, the task records in the task management list will get lost.
- In the object list of your bucket, click Task Center in the upper right corner.
- View the records of uploading objects, restoring objects in batches, changing storage classes in batches, or deleting folders.
- Click Clear Records to clear all task records.
- On the Upload tab page, you can click Pause All or Start All to manage upload tasks in batches.
