- User Guide
- Best Practices
- FAQs
Show all
Importing a Whitelist
This section describes how to import an IP address whitelist. MTD will ignore threats related to the IP addresses or domain names contained in the whitelist.
- Currently, only one whitelist file with a can be maximum of 10,000 IP address or domain names can be uploaded.
- Plaintext format: In your trusted IP list and intelligence file, ensure that each line contains only one IP address. For details, see How Do I Edit and Upload a Plaintext File to OBS?
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the navigation pane on the left and choose Security & Compliance > Managed Threat Detection.
Figure 1 Home page of MTD - Choose Settings > Threat Intelligence in the left navigation pane.
- On the Whitelist tab, click Add Whitelist. The Add Whitelist dialog box is displayed.
Figure 2 Add a whitelist
Table 1 Whitelist file parameters Parameter
Example Value
File Name
Name of the intelligence file to add
SecurityList
Intelligence Type
Content type of the file to be uploaded from the OBS bucket to MTD
- IP: MTD will detect threats based on the IP addresses in the whitelist file.
- Domain name: MTD will detect threats based on the domain names in the whitelist file.
MTD ignores log information that is associated with the IP addresses or domain names in the whitelist file.
IP
Bucket Name
Name of the OBS bucket where the file is located
If no OBS bucket is available, click View/Create OBS Bucket. For details, see Creating a Bucket.
obs-mtd-bejing4
Object Name
Name of the object in the bucket that stores the intelligence
NOTICE:The object name must contain the file name extension.
mtd-securitylist-ip.txt
Storage Path
Path of the OBS bucket storing the intelligence file
obs://obsmtd-beijing4/mtd-securitylistip.txt
- Confirm the information and click OK. If the added file is displayed in the whitelist pane, the operation is successful.
