- User Guide
- Best Practices
- FAQs
Show all
Disabling Log Detection
This section describes how to disable log detection. After the function is disabled, MTD will not detect new log data generated by your services, which does not affect the historical detection and results. You can also unsubscribe from the detector of the current region.
You have purchased MTD and created a detector in the current region.
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the navigation pane on the left and choose Security & Compliance > Managed Threat Detection.
Figure 1 Home page of MTD - In the navigation pane on the left, choose Settings > Detection Settings.
- Select the target service and click
to disable log detection for the service. If the icon under the service name changes to
, the real-time log detection is successfully disabled.
Figure 2 Log detection disabledNOTE:
After you disable the log detection for a service, MTD will stop detection newly generated logs, but the historical detection results are kept.
