Updated on 2023-01-05 GMT+08:00
Enabling Log Detection
You have purchased MTD and created a detector in the current region.
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the navigation pane on the left and choose Security & Compliance > Managed Threat Detection.
    Figure 1 Home page of MTD
  4. Choose Settings > Detection Settings in the left navigation pane.
  5. Select the target service and click to enable log detection for the service. If the icon under the service name changes to , the real-time log detection is successfully enabled.
    Figure 2 Log detection enabled
    • When you enable service log detection for the first time, a dialog box is displayed, asking you to configure a tracker accessing the service logs.
    • You can click Create a Tracker to switch to the Tracker List page. For details, see Step 2: Create a Tracker.
    • You can click Learn how to view how to create a tracker in the CTS user guide.
