EIP Events That Can Be Monitored
Function Description
On Cloud Eye, you can use event monitoring for data collection, query, and alarm reporting. You can create alarm rules for both system events and custom events. When there are specified events, you will receive alarm notifications.
Namespace
SYS.EIP
| Event Source | Namespace | Event Name | Event ID | Event Severity | Description | Solution | Impact |
| EIP | SYS.EIP | EIP bandwidth overflow | EIPBandwidthOverflow | Major | The used bandwidth exceeded the purchased one, so the network may become slow or packets may be lost. The event value reflects the peak in a monitoring period, and the value of the EIP inbound and outbound bandwidth is taken from a specific point within that period.
NOTE: The EIP bandwidth overflow event is available only in certain regions. You can check the regions on the console. | Check whether the used EIP bandwidth keeps increasing and whether services are normal. Increase the bandwidth if necessary. | The network becomes slow or packets are lost. |
| Delete EIP | deleteEip | Minor | The EIP was released. | Check whether the EIP was released by mistake. | The resource cannot access the Internet. | ||
| EIP blocked | blockEIP | Critical | The used bandwidth of an EIP exceeded the threshold, so the EIP was blocked and packets were discarded. Such an event may be caused by DDoS attacks. For details about the threshold, see CNAD Basic. | Replace the EIP to prevent services from being affected. Locate and deal with the fault. | Services are impacted. | ||
| EIP unblocked | unblockEIP | Critical | The EIP was unblocked. | Use the previous EIP to save resources. | None | ||
| Start DDoS traffic scrubbing | ddosCleanEIP | Major | Traffic scrubbing on the EIP was started to prevent DDoS attacks. | Check whether the EIP was attacked. | Services may be interrupted. | ||
| Stop DDoS traffic scrubbing | ddosEndCleanEip | Major | Traffic scrubbing on the EIP to prevent DDoS attacks was ended. | Check whether the EIP was attacked. | Services may be interrupted. | ||
| Enterprise-class QoS bandwidth limit exceeded | EIPBandwidthRuleOverflow | Major | The allocated QoS bandwidth was exceeded, which may slow down the network or cause packet loss. The event value reflects the peak in a monitoring period, and the value of the EIP inbound and outbound bandwidth is taken from a specific point within that period.
| Check whether the used EIP bandwidth keeps increasing and whether services are normal. Increase the bandwidth if necessary. | The network becomes slow or packets are lost. | ||
| Unbound EIP | EipNotBoundStatus | Warning | The EIP is not bound to any resource. | N/A | When an EIP is unbound, you will be billed for IP reservation fees and bandwidth fees (billed by bandwidth). |
