Help Center/ Data Lake Insight/ User Guide/ Configuring DLI to Read and Write Data from and to External Data Sources/ Managing Data Source Access Credentials Using DEW/ Spark Jar Jobs Using DEW to Acquire Access Credentials for Reading and Writing Data from and to OBS
Updated on 2025-08-15 GMT+08:00
To write the output data of a Spark Jar job to OBS, AK/SK is required for accessing OBS. To ensure the security of AK/SK data, you can use Data Encryption Workshop (DEW) and Cloud Secret Management Service (CSMS) for unified management of AK/SK, effectively avoiding sensitive information leakage and business risks caused by hard-coded or plaintext configuration of programs.
This section walks you through on how a Spark Jar job acquires an AK/SK to read and write data from and to OBS.
  • A shared secret has been created on the DEW console and the secret value has been stored. For details, see Creating a Shared Secret.
  • An agency has been created and authorized for DLI to access DEW. The agency must have been granted the following permissions:
    • Permission of the ShowSecretVersion interface for querying secret versions and secret values in DEW: csms:secretVersion:get.
    • Permission of the ListSecretVersions interface for listing secret versions in DEW: csms:secretVersion:list.
    • Permission to decrypt DEW secrets: kms:dek:decrypt
      For details about agency permission examples, see Customizing DLI Agency Permissions and Agency Permission Policies in Common Scenarios.
  • DEW can be used to manage access credentials only in Spark 3.3.1 (Spark general queue scenario) or later. When creating a Spark job, select version 3.3.1 and configure the information of the agency that allows DLI to access DEW for the job.
    For details about how to create a custom agency and configure it, see Customizing DLI Agency Permissions.
  • To use this function, you need to configure AK/SK for all OBS buckets.
Syntax
On the Spark Jar job editing page, set Runtime Configuration as needed. The configuration information is as follows:
Different OBS buckets use different AK/SK authentication information. You can use the following configuration method to specify the AK/SK information based on the bucket. For details about the parameters, see Table 1.
spark.hadoop.fs.obs.bucket.USER_BUCKET_NAME.dew.access.key= USER_AK_CSMS_KEY
spark.hadoop.fs.obs.bucket.USER_BUCKET_NAME.dew.secret.key= USER_SK_CSMS_KEY
spark.hadoop.fs.obs.security.provider = com.dli.provider.UserObsBasicCredentialProvider
spark.hadoop.fs.dew.csms.secretName= CredentialName
spark.hadoop.fs.dew.endpoint=ENDPOINT
spark.hadoop.fs.dew.csms.version=VERSION_ID
spark.hadoop.fs.dew.csms.cache.time.second =CACHE_TIME
spark.dli.job.agency.name=USER_AGENCY_NAME
Parameter Description
Table 1 Parameters
Mandatory
Default Value
Data Type
Yes
None
String
USER_BUCKET_NAME needs to be replaced with the user's OBS bucket name.
The value of this parameter is the key defined by the user in the CSMS shared secret. The value corresponding to the key is the user's access key ID (AK). The user must have the permission to access the bucket on OBS.
Yes
None
String
The value of this parameter is the key defined by the user in the CSMS shared secret. The value corresponding to the key is the user's secret access key (SK). The user must have the permission to access the bucket on OBS.
Yes
None
String
OBS AK/SK authentication mechanism, which uses DEW-CSMS' secret management to obtain the AK and SK for accessing OBS.
The default value is com.dli.provider.UserObsBasicCredentialProvider.
Yes
None
String
Name of the shared secret in DEW's secret management.
Configuration example: spark.hadoop.fs.dew.csms.secretName=secretInfo
Yes
None
String
Endpoint of the DEW service to be used.
See Regions and Endpoints.
Configuration example: spark.hadoop.fs.dew.endpoint=kms.cn-xxxx.myhuaweicloud.com
No
Latest version
String
Version number (certificate version identifier) of the common credential created in DEW's credential management.
If not specified, the latest version of the common credential is obtained by default.
Configuration example: spark.hadoop.fs.dew.csms.version=v1
No
3600
Long
Cache duration after the CSMS shared secret is obtained during Spark job access.
The unit is second. The default value is 3600 seconds.
spark.hadoop.fs.dew.projectId
No
Yes
String
ID of the project DEW belongs to. The default value is the ID of the project where the Spark job is.
See Obtaining a Project ID.
Yes
String
Custom agency name.
Sample Code
This section describes how to write processed DataGen data to OBS. You need to modify the parameters in the sample Java code based on site requirements.
  1. Create an agency for DLI to access DEW and complete authorization.
    For details, see Customizing DLI Agency Permissions.
  2. Create a shared secret in DEW. For details, see Creating a Shared Secret.
    1. Log in to the DEW management console.
    2. In the navigation pane on the left, choose Cloud Secret Management Service > Secrets.
    3. On the displayed page, click Create Secret. Set basic secret information.
  3. Set job parameters on the DLI Spark Jar job editing page.
    Spark Arguments
    spark.hadoop.fs.obs.security.provider=com.dli.provider.UserObsBasicCredentialProvider
    spark.hadoop.fs.dew.csms.secretName=obsAkSk
    spark.hadoop.fs.dew.endpoint=kmsendpoint
    spark.hadoop.fs.dew.csms.version=v3
    spark.dli.job.agency.name=agency
  4. Sample Code
    For details about the sample code, see Using Spark Jar Jobs to Read and Query OBS Data.
