Configuring a Bucket for Saving Job Results
DLI allows you to save the results of SQL jobs to a DLI job bucket for persistent storage and management.
Notes and Constraints
- Once enabled, the job result saving policy cannot be disabled. Job results will always be saved to the DLI job bucket specified by the user.
- For users who subscribed to and used DLI before May 2024, a service ticket must be submitted to enable SQL job result saving to a DLI job bucket.
Starting from May 2024, new users can use this feature without submitting a request.
- This parameter is only available for Spark SQL queues.
- Before enabling this feature, make sure you have configured a DLI job bucket. For how to configure a DLI job bucket, see Step 1: Configure the DLI Job Bucket.
To check if you have enabled saving SQL job results to a DLI job bucket, see How Do I Check if Job Result Saving to a DLI Job Bucket Is Enabled for a SQL Queue?.
For more constraints on configuring the DLI job bucket, see Configuring a DLI Job Bucket.
- Log in to the DLI management console.
- In the navigation pane, choose Global Configuration > Project.
- On the Project page, click
next to Job Bucket to configure bucket information. Figure 1 Project
- Click
to view available buckets. - Select the bucket for storing the temporary data of the DLI job and click OK. Temporary data generated during DLI job running will be stored in the OBS bucket.Figure 2 Setting the job bucket
Step 2: Enable Job Result Saving to a DLI Job Bucket
- In the navigation pane, choose Resources > Queue Management.
- Locate the queue for which you want to set properties, click More in the Operation column, and select Set Property.
- Go to the queue property setting page and set property parameters. Table 2 describes the property parameters.
Table 1 Queue properties Property Type
Property
API Parameter
Job result saving policy
Set Result Saving Policy
job.saveJobResultToJobBucket
Whether to save job results to a DLI job bucket.
- Click OK.
- Method 1: View the result path on the SQL job details page.
- In the navigation pane, choose Job Management > SQL Jobs.
- Locate a desired SQL job and click
next to the queue name to expand the job details. - Check the result path in the job details.
- If the result path displays a custom DLI job bucket, the feature of saving job results to a DLI job bucket is enabled for the queue running the job.
- If the result path is not displayed in the job details, the feature is not enabled for the queue running the job.
- Method 2: Check whether job result saving to a job bucket is enabled in the SQL queue properties.
- On the Set Property dialog box that appears, check whether the feature is enabled.
Job Result Return Limits When Using JDBC to Submit SQL Jobs to DLI
| JDBC Version | Result Return Limit | Description |
| dli-jdbc-1.X | No limit (controlled by the directfetchthreshold parameter, which defaults to 1000). | You can adjust the directfetchthreshold parameter to set the limit on the number of job results returned. |
| dli-jdbc-2.X (for users who subscribed to DLI before May 2024) | A maximum of 1,000 job results can be returned. | Saving job results into buckets is currently in limited use. To use it, submit a service ticket. Once enabled, configure a bucket for saving job results as described in this section. More than 1,000 results can be queried from the job bucket. |
| dli-jdbc-2.X (for users who subscribed to DLI from May 2024 onward) | No limit | New users can save job results to a configured DLI job bucket without having to submit a request first. |
