Help Center/
Data Lake Insight/
User Guide/
Creating an Elastic Resource Pool and Creating Queues Within It/
Managing Queues/
Deleting a Queue
Updated on 2025-08-15 GMT+08:00
Deleting a Queue
You can delete a queue based on actual conditions.
- This operation will fail if there are jobs in the Submitting or Running state on this queue.
- Deleting a queue does not cause table data loss in your database.
- In the navigation pane on the left of the DLI management console, choose Resources > Queue Management.
- Locate the row where the target queue locates and click Delete in the Operation column.
Figure 1 Deleting a Queue
If Delete in the Operation column is gray, the current user does not have the permission of deleting the queue. You can apply to the administrator for the permission.
