Updated on 2025-08-26 GMT+08:00
Applying for DCC Resources
You can apply for DCC resources after you have enabled your DeC.
- Log in to the DeC console.
 - Switch to the target region where DeC is enabled.
 - In the upper right corner, click Apply for Resource and set parameters as prompted.
 - Click Next.
 - Confirm the configuration and click Submit.
 - After the task is successfully delivered, close the task creation page and wait for the administrator's approval.
