- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Change Management/
Change Center/
Implementing and Closing a Change Ticket
After a change ticket is approved, implement the change within the specified time window according to the change solution.
- Log in to COC.
- In the navigation pane on the left, choose Change Ticket Management > Change Center. On the displayed page, locate a pending ticket and click the ticket title or click Change Start in the Operation column of a change record to view the change details and review the change. If the change solution is associated with a job, < execute the job first. If the change solution is associated with a change guide, implement the change according to the change guide.
Figure 1 Change execution
- After the change is complete, click the step for finishing the change and enter the change result.
Figure 2 Specifying the change result
- After the change result is specified, click Close to close the change ticket.
Figure 3 Closing a change ticket
Parent topic: Change Center
