- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Account Management/
Logging In to a Host Without Any Passwords
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. In the Routine O&M area, click Account Management.
- Click the Accounts tab. By Resource is used to manage all purchased host instances, and By Application is used to manage purchased hosts that are bound to applications.
Figure 1 Accounts
- You can search for the host resource to be remotely logged in to from the resource or application perspective and click Password-free Login in the Operation column to remotely log in to the host.
Figure 2 Remotely logging in to a cloud server
There are three prerequisites for a successful remote login to a host:
1. A UniAgent has been installed and is running on the target host. The UniAgent version must be later than 1.1.3.8.
2. The host is in the running state.
3. The account configured in the baseline exists on the host and can be used to log in to the host.
- In the Select Login Account dialog box, select the account with which you want to log in to the host from the Login Account drop-down list and click OK.
Figure 3 Selecting the account you want to use for loginFigure 4 The black screen command page is displayed.
Parent topic: Account Management
