- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Parameter Management/
Notification Rules/
Unmodified Notifications
- The unmodified notification time cannot be earlier than the parameter creation or modification time.
Figure 1 If the notification time is earlier than the system time
- If there is a policy for deleting the parameter upon expiration, the unmodified notification time cannot be later than the time of deletion upon expiration.
Figure 2 If the unmodified notification time is later than the time of deletion upon expiration
Parent topic: Notification Rules
