- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Basic Configurations/
Process Management/
Incident Handling Process/
Managing Incident Levels
- Log in to COC.
- In the navigation pane, choose Basic Configurations > Process Management. On the displayed Incident Process tab page,click the Incident Level tab.
Figure 1 Incident level
- Locate the target data records, and click Edit in the Operation column to modify the incident level and description. If a level does not need to be enabled, you can disable it.
- After the modification, you can view the latest incident level list on the Incidents page.
Figure 2 Editing incident levels and descriptions
Parent topic: Incident Handling Process
