Help Center/ Cloud Operations Center/ User Guide/ Automated O&M/ OS Version Change/ Summarizing OS Version Upgrade Compatibility Issues
Updated on 2026-09-21 GMT+08:00
When you upgrade your OS from RHEL 7.9 to RHEL 8.x, the identified compatibility issues are listed in Table 1 for your reference. The recommended solutions are provided to speed up your device recovery, reducing the upgrade impacts on the system.
Table 1 Summary of compatibility issues during OS upgrade
Component Compatibility Issue Compatibility Issue Category Description Check Procedure Recovery Suggestion
vsftpd
(FTP server software)
RHEL 8 does not support tcp_wrappers configuration (a simple firewall software based on the TCP layer).
The configuration item is discarded.
RHEL 8 does not support tcp_wrappers configuration. Therefore, related configuration items need to be removed to reduce system component redundancy. Check related configurations. firewalld can be used instead.
In RHEL 8, check whether the vsftpd configuration is supported, especially whether tcp_wrappers=YES is not set in the configuration file and whether vsftpd-related configurations can be found in the tcp_wrappers configuration file. You can perform the following steps:
  1. Check the vsftpd configuration file.
    Open the main configuration file /etc/vsftpd/vsftpd.conf of vsftpd and check whether tcp_wrappers=YES has been set.
    Run the following command. If the command output is empty, tcp_wrappers=YES is not set.
    bash:
    grep -i "tcp_wrappers" /etc/vsftpd/vsftpd.conf
  1. Check the tcp_wrappers configuration file.
    The tcp_wrappers configuration file is usually located in /etc/hosts.deny and /etc/hosts.allow. You need to ensure that these files do not contain rules for vsftpd.
    Run the following commands. If no output is displayed, the vsftpd-related configuration does not exist in the tcp_wrappers configuration file.
    bash:
    grep -i "vsftpd" /etc/hosts.deny
    grep -i "vsftpd" /etc/hosts.allow
  2. Subject to a comprehensive assessment.
    Based on the results of the preceding two steps, if the vsftpd configuration file does not contain tcp_wrappers=YES and the tcp_wrappers configuration file does not contain rules for vsftpd, the vsftpd configuration meets the requirements.
The preceding steps ensure that the vsftpd configuration does not conflict with tcp_wrappers.
Rectify the fault by referring to the official document Replacing TCP Wrappers in RHEL 8 and 9.
openssh
(SSH login)
  • The preset value is changed.
  • The value of the configuration item is discarded.
  • The configuration item is discarded.
Some security algorithms in the Ciphers and MAC configurations have expired. You need to query keywords and delete the discarded security algorithms.
  • The Ciphers tool is used to specify the encryption mode for transmitting data in an SSH session.
  • Message Authentication Code (MAC) is used to verify the data integrity and authenticity during the SSH transmission, ensuring that data is not tampered with.
Configure the Ciphers and MAC keywords in the configuration file and check whether there are discarded security algorithms.
Run the following command to open the configuration file.
vi /etc/ssh/sshd_config
Delete the following discarded security algorithms.
removed_ciphers = [
        "blowfish-cbc",
        "cast128-cbc",
        "arcfour",
        "arcfour128",
        "arcfour256",
removed_macs = [
        "hmac-ripemd160",
openssh
(SSH login)
ShowPatchLevel is a configuration item of the SSH Daemon (sshd). It specifies whether to display the patch level of the binary file in the identity authentication string. This option applies only to SSH 1 and is disabled by default (that is, the patch level is not displayed).
ShowPatchLevel is used to display the patch level of sshd to the client. In RHEL 8, sshd disables SSH 1 by default and supports only SSH 2. The ShowPatchLevel configuration is useless in SSH 2. SSH 1 is considered insecure. If you need to view the patch level of a specific SSH server version, you may need to refer to the compilation configuration or related documents of the software instead of relying on this outdated option.
Delete the configuration file related to ShowPatchLevel.
Run the following command to check whether ShowPatchLevel can be found.
bash:
grep "ShowPatchLevel" /etc/ssh/sshd_config
Run the following command to delete the ShowPatchLevel parameter:
bash:
sed -i /^\\s*ShowPatchLevel.*$/Id
openssh
(SSH login)
The value of PermitRootLogin must be set to YES.
PermitRootLogin is used to determine whether the root user can directly log in to the system through SSH. When RHEL 7 is upgraded to RHEL 8, if the old sshd_config configuration (for example, PermitRootLogin without-password) is used, and the root user may fail to log in to the system through SSH. In this case, you need to change the value of PermitRootLogin to yes for compatibility to allow root to log in to the system through SSH.
Run the following command. If the output is empty, there is no PermitRootLogin statement.
bash:
grep "PermitRootLogin" /etc/ssh/sshd_config
bash:
sed -i "s#^PermitRootLogin.*#PermitRootLogin yes#g" /etc/ssh/sshd_config
Bind
(DNS server software)
  • dnssec-lookaside is no longer supported. The dlv.isc.org on which dnssec-lookaside depends stops providing services and becomes invalid.
  • The preset value of listen-on-v6 is changed.
  • The preset value of the configuration item is changed.
  • dnssec-lookaside specifies the DLV (Delegation Signer) server that is used for DNSSEC verification. With the development of DNSSEC technologies, BIND does not support DLV signature verification by default. Therefore, the dnssec-lookaside statement may not be accepted. After the upgrade to RHEL 8, BIND ignores the configuration (No error is reported and the configuration becomes invalid). If a customized lookaside zone is configured, invalid queries may occur, affecting the DNS response efficiency. If you need to use the DNSSEC function, you are advised to check the latest BIND documentation to learn how to correctly configure DNSSEC.
  • listen-on-v6 specifies the IPv6 address to be listened on in the BIND configuration file. If listen-on-v6 is not explicitly set in your configuration file, BIND determines whether to listen on IPv6 connections based on the preset actions. Generally, the preset actions are to listen to all available network interfaces, including IPv6 interfaces. This means that even if you do not explicitly set listen-on-v6 in the configuration file, BIND may already be listening on IPv6 requests.
listen-on-v6 is disabled by default on RHEL 7 and enabled by default on RHEL 8. RHEL 8 listens to all available IPv6 interfaces even if listen-on-v6 is not configured. After the upgrade, the configuration may conflict with the expectation. If listen-on-v6 is disabled (for example, listen-on-v6 { none; };) on RHEL 7, the configuration may become invalid due to configuration changes or priority changes after the upgrade. It is recommended that you configure the parameter explicitly, ensuring that the configuration is the same as expected.
  1. Run the following command. If the output is empty, no dnssec-lookaside statement exists.
    bash:
    grep "dnssec-lookaside" /etc/named.conf
  1. Run the following command. If the output is empty, no listen-on-v6 statement exists.
    bash:
    grep "listen-on-v6" /etc/named.conf
Delete dnssec-lookaside. If this function is still required, modify it by referring to the official document.
Display the configuration switch or do not configure listen-on-v6 based on the expected usage.
pam_pkcs11.so
pam_krb5.so
The so library is no longer supported.
  • pam_pkcs11.so is a Pluggable Authentication Module (PAM). It allows the system to use PKCS#11-compliant smart cards or other hardware tokens for user authentication. PKCS#11 is a standard API used to interact with various encryption devices, including smart cards and HSMs. In Red Hat Enterprise Linux (RHEL) 7, pam_pkcs11.so depends on pkcs11-helper (version 1.11 or earlier). In RHEL 8, pkcs11-helper is upgraded to version 1.25 or later, and several legacy APIs are removed. As a result, drivers compiled against the older library are incompatible with the new environment. pam_pkcs11 in RHEL 7 supports old parameters, and some old parameters in RHEL 8 are discarded or renamed.
  • pam_krb5.so is a PAM module. It allows the system to use the Kerberos protocol for user authentication. Kerberos is a network identity authentication protocol. It uses the key encryption technology to provide secure identity authentication between clients and servers. It is applicable to unified identity authentication (such as intra-domain login and network service access) of multiple services in distributed network environments. The old pam_krb5.so supported old features (such as DES encryption) of Kerberos 5. However, RHEL 8 has disabled these insecure features.
Run the following commands to query the so library configuration:
bash:
grep "pam_pkcs11.so" /etc/pam.d/*
grep "pam_krb5.so" /etc/pam.d/*
Remove or comment out the unsupported so library configuration.
For details, see official documents.
pam_tally2.so
pam_tally2.so is a Pluggable Authentication Module (PAM), used to collect statistics on and limit the number of user login failures. This module can monitor the number of consecutive login failures of a user. When the preset threshold is reached, the user account is temporarily locked to prevent brute-force attacks or malicious login attempts. This enhances system security and is applicable to multiple authentication scenarios such as local login and SSH remote login.
In RHEL 8, pam_tally2.so is replaced by pam_faillock.so and no longer installed by default and no longer maintained by the official website. If pam_tally2.so is still referenced in the PAM configuration file (such as /etc/pam.d/sshd and /etc/pam.d/system-auth) after the upgrade, the module cannot be found. (module not found is reported.) As a result, the authentication process fails.
Run the following command to query the so library configuration.
bash:
grep "pam_tally2.so" /etc/pam.d/*
firewalld
(Firewall software)
Many firewall rules are changed, and some usages are no longer supported.
The configuration item is changed.
firewalld simplifies the supported firewall rules, especially ebtables and ipset types. Only the subsets are supported. If the unsupported types are used, the rules will become invalid or the firewall will fail to be started.
Exclusion method:
  • Supported ebtables types: filter and nat
  • Supported ipset types: hash:ip, hash:mac, and hash:net
You need to check all firewall rules and configuration files, replace the types that do not meet the requirements with the supported types, and delete the unsupported usage (rectify the fault according to the description in the corresponding version document. For details, see RHEL 8 firewall configuration).
Btrfs
(New file system)
The Btrfs component is discarded in RHEL 8.
Component deprecation
Btrfs is a modern file system designed to meet high-end storage requirements. It supports advanced functions such as snapshot, RAID, and dynamic volume management. Btrfs is an optional component in RHEL 7.
Btrfs is discarded in RHEL 8. Btrfs is not provided as an optional file system during the upgrade. Partitions cannot be formatted as Btrfs during system installation. The core tool package of Btrfs is removed from the official repository.
You can check and rectify the fault by referring to official documents.
  • If a Btrfs-formatted file system is mounted, a direct upgrade cannot guarantee the integrity of data on the Btrfs partition. It is recommended that data in the Btrfs partition be migrated to file systems (XFS and Ext4) supported by RHEL 8.
  • If no Btrfs-formatted file system is mounted but the Btrfs module is being used, run the modprobe -rv btrfs command to remove the Btrfs module.
  1. If the upgrade is performed directly, the data integrity of the Btrfs partition cannot be ensured. Migrate data in the Btrfs partition to file systems (XFS and Ext4) supported by RHEL 8.
    Uninstall all Btrfs-formatted file systems.
    bash:
    umount /mnt/path/to/btrfs
  1. Uninstall the Btrfs kernel module.
    Run the following command to safely uninstall the Btrfs module from the system.
    bash:
    sudo modprobe -r btrfs
XFS
(High-performance log file system)
XFS is a highly scalable, high-performance, robust, and mature 64-bit log file system that supports large files and file systems on a single host. It is the preset file system in RHEL 8 and has some discarded configuration items.
Check whether any discarded configuration items exist.
  • removed from kernel in 4.0
    • nodelaylog
    • delaylog
    • ihashsize
    • irixsgid
    • osyncisdsync
    • osyncisosync
  • removed from kernel in 4.19
    • nobarrier
    • barrier
grep -E 'nodelaylog|delaylog|ihashsize|irixsgid|osyncisdsync|osyncisosync|nobarrier|barrier' /etc/fsta
Delete the discarded configuration items and replace them with new configuration items in the manual.
Docker
(Container)
Docker is replaced by Podman.
Component replacement
Docker software package is provided in RHEL 7. In RHEL 8, Docker is discarded and Podman is recommended. You need to migrate the existing Docker containers to adapt to the RHEL 8 environment. For the upgrade, you may manually reinstall the system or use the Leapp tool.
babeld
(Network traffic analysis tool)
Babeld is replaced by RIP, OSPF, or EIGRP.
In RHEL 8, the Babeld daemon (originally part of the Quagga implementation) is no longer included in FRRouting (FRR) due to licensing issues. This means that if you need to use the Babel protocol, you may need to find other alternatives or manually install Babeld. FRR has removed Babeld from its official software package. Therefore, users need to process the Babel protocol separately. If you have this requirement, you can obtain Babeld from the official website of the Babel project and install it.
bash:
dnf list installed | grep -E "babeld|frr"
If the preceding package is not displayed in RHEL 8 and FRR has been installed but the Babel component is not installed, Babeld has been removed.
If the network traffic analysis function is required, you need to manually deploy Babeld (download the source code from the Babel official website, compile and install Babeld) or install alternative software (such as OSPF, RIP, and IS-IS) in RHEL 8.
GRUB2
Partition size is insufficient.
Partition size
In the GRUB 2 startup mechanism, core image core.img is an intermediate image that carries core function modules required for startup, such as basic hardware drivers, file system support, and boot logic. This image needs to be installed in a specific embedded area of the disk. If the embedded area is insufficient, GRUB 2 fails to install core.img. Generally, an error message is displayed, indicating that the embedded area is insufficient. As a result, the boot program cannot be installed. core.img generally is 20 KB to 30 KB.
For a traditional MBR disk, run the following command.
bash:
fdisk -l
Check the starting position of the first disk. The MBR occupies one sector, so the size of the embedded area is (size of the start sector – 1) × 512 bytes. In this way, you can check whether the space of the embedding area is sufficient.
If the space is insufficient, the in-place upgrade is not supported. You need to reinstall the system or format the partition.
GRUB2
GRUB 1 cannot be upgraded. GRUB 1 has been discarded in later versions.
Starting from RHEL 7, GRUB Legacy has been replaced by GRUB 2. Therefore, GRUB Legacy is not usually found in the MBR on a newer system.
If you have installed GRUB 2, you can check the /boot/grub2/grub.cfg file or use the grub-install command to confirm the GRUB 2 status and indirectly determine whether GRUB Legacy has been removed.
bash:
grub-install --version
Or,
grub2-install --version
If the system returns the GRUB 2 version information, GRUB 2 has been correctly installed, and GRUB Legacy has been removed. Run the ls -ld /boot/grub command to check whether GRUB Legacy residual exists.
bash:
ls -ld /boot/grub
Install GRUB 2 by referring to the official document.
pacemaker cluster
Cluster software upgrade is not supported.
Leapp upgrade from RHEL 7 to RHEL 8 fails for pacemaker cluster. Red Hat officially states that Leapp is not recommended for in-place upgrade of cluster environments where High Availability or Resilient Storage add-ons are deployed.
Check whether the related configuration file exists.
bash:
ls /etc/corosync/corosync.conf
ls /var/lib/pacemaker/cib/cib.xml
If No such file or directory is displayed, no related configuration file exists.
In-place upgrade is not recommended. You can replace nodes one by one, perform distributed migration, and destroy the entire cluster.
sh -c pcs cluster stop --all --wait && pcs cluster destroy --all
KDE
KDE desktop software is not supported.
In RHEL 8, the KDE desktop environment is unavailable by default. If KDE-related software packages are installed in your system, they will be removed during the upgrade. Therefore, after the upgrade is complete, your system does not have any desktop environment.
If a desktop environment is required, install the GNOME replacement software.
Run the following command to check whether the GNOME desktop software is installed.
bash:
rpm -qa | grep -i gnome-shell
Manually install the GNOME desktop software after the upgrade.
dnf groupinstall "Server with GUI" -y
Or,
dnf groupinstall "Workstation" -y
sendmail
TCP Wrappers is not supported in later versions of sendmail.
During the upgrade from RHEL 7 to RHEL 8, sendmail conflicts with TCP Wrappers. Check whether sendmail is installed and whether the configuration needs to be updated. If the TCP Wrappers tool is used, do not upgrade sendmail. To prevent sendmail service exceptions after the upgrade, perform the check operations before the upgrade. If sendmail depends on TCP Wrappers, do not upgrade the sendmail or adjust the configuration.
  1. Check whether sendmail is installed.
    bash:
    rpm -qa | grep -i sendmail
  1. Check whether sendmail depends on TCP Wrappers. The core dependency library of TCP Wrappers is libwrap.so.
    bash:
    ldd $(which sendmail) | grep libwrap
  1. Check whether the TCP Wrappers is used.
    bash:
    grep -i sendmail /etc/hosts.allow /etc/hosts.deny
    • If the output contains configurations such as sendmail: 192.168.1.0/24, TCP Wrappers is used.
    • If no output is displayed, the TCP Wrappers is not used. After the upgrade, only the libwrap dependency is removed, and sendmail can run properly.
Remove the discarded configuration items or migrate the configuration items to the new ones.
The original TCP Wrappers configuration is used for sendmail access control. Use firewalld for the same function (as recommended in RHEL 8).
SpamAssassin
Backward incompatibility
RHEL 8 enhances software security, standardization, and modernization, and the SpamAssassin (e-mail spam filtering tool) is backward incompatible. Some configurations, command options, or protocols in RHEL 7 may be removed or modified in the new version.
  • In RHEL 8, the --ssl option of the spamc command line tool no longer supports passing additional parameters. This means that if you have used the format such as --ssl=hostname:port, you need to directly specify the host name and port.
  • In RHEL 8, the --ssl-version option is no longer supported when the spamd service is started. If this option is in your configuration file, remove it or replace it with other ways to control the SSL version.
  • For security purposes, SpamAssassin in RHEL 8 does not support SSLv3. If you still rely on SSLv3, upgrade to a more secure protocol version.
  • In RHEL 8, the SpamAssassin service type has been changed from forking to simple This may affect how the SpamAssassin service is configured and managed. Ensure that your system service management tool (such as systemd) correctly processes this change.
  • In RHEL 8, the sa-update tool no longer supports the SHA-1 to verify rule files. This means that you need to update any scripts or configurations that depend on SHA-1 verification to use a more secure hash algorithm.
For the migration of configuration files, most of the work will be automatically completed by the SpamassassinConfigUpdate operator.
Many incompatible items and manual migration.
kernel
There are multiple versions of the kernel-debug rpm package.
Kernel package conflicts
If kernel-debug exists, the system boot option may be affected after the OS version is upgraded. As a result, the system cannot be accessed after the system is restarted.
Run the following command to view the system boot option information.
bash:
grubby --info=ALL
View the preset boot option and delete the configuration parameters.
bash:
grubby --default-index
grubby --update-kernel=default boot option index --remove-args="rd.break easyup.rollback"
kernel
There are multiple versions of the kernel-devel rpm package.
kernel-devel is a kernel development file package. The content (such as kernel header files and module development tools) is strongly bound to a specific kernel version. Coexistence of multiple versions may cause path conflicts and dependency disorder. When processing the upgrade, the package manager needs to verify the dependency chains of the old and new versions. Coexistence of multiple versions complicates the dependency parse logic. As a result, errors such as version mismatch and dependency loop may occur. The upgrade process may be interrupted or the installation may be incomplete. Before the upgrade, ensure that the kernel-devel package does not exist in the environment.
Delete the kernel-devel package corresponding to the unused kernel so that only one kernel-devel package can be installed.
  1. List the installed kernel development packages.
    Run the following command to view all kernel debugging packages installed in the current system.
    bash:
    rpm -qa | grep kernel-devel
  2. Query the kernel information that is in use.
    bash:
    uname -r
  3. Uninstall the kernel development package.
    bash:
    sudo yum -y remove <package_name>
    Note: <package_name> indicates the name of the package to be uninstalled.
Run the following command to uninstall the kernel development package.
bash:
device-mapper-multipath
device-mapper-multipath is used to aggregate multiple physical storage paths into one logical path, implementing storage access redundancy and load balancing. One of its core functions is path health check. path_checker is used to define the check method and determine whether the storage path is available.
In RHEL 7, the default value of path_checker is directio. In RHEL 8, the default value of path_checker is tur. If the old configuration of path_checker is still retained in your configuration file, it may conflict with the default configuration.
Run the following command to check the current configuration.
bash:
grep "default_path_checker|detect_prio|detect_path_checker|reassign_maps|retain_attached_hw_handler" /etc/multipath.conf
Remove the original configuration or display the configuration.
Satellite
The data storage location is changed.
During the upgrade from RHEL 7 to RHEL 8, the /var/lib/pgsql/data directory contains original PostgreSQL data, and the storage space is insufficient when data is migrated from /var/opt/rh/rh-postgresql12/lib/pgsql/data/ to /var/lib/pgsql/data required by RHEL 8. As a result, automatic migration cannot be performed.
Check the installation status and version of RHEL Satellite in the current system.
bash:
rpm -q Satellite
Precautions:
  • The Satellite package is not found, but the Satellite service is in use.
  • The queried version does not match the upgrade path. The upgrade is not performed step by step according to the official requirements (for example, the version is directly upgraded from 6.7 to 6.11 with the intermediate versions skipped), or the version is earlier than 6.7. (The issues listed on the official website are targeted for upgrades from version 6.7 or later versions.)
  • The package status is abnormal.
Manually migrate data by referring to the official document.
SSSD
Key changes have been made to the System Security Services Daemon (SSSD) configuration in RHEL 8, which are related to compatibility and default behavior changes. These changes may affect system identity authentication and user information management.
1. id_provider=local is no longer supported and will be ignored.
2. The ldap_groups_use_matching_rule_in_chain option is removed and will be ignored.
3. The ldap_initgroups_use_matching_rule_in_chain option is removed and will be ignored.
4. The preset value of ldap_sudo_include_regexp is changed from true to false.
Comment out the discarded configuration items.
Modify the preset value.
tcp_wrappers
tcp_wrappers discarded
TCP Wrappers is a security tool working at the fourth layer (transmission layer). It performs access control and security detection on specific services with stateful connections (TCP). All programs that invoke the libwrap.so library file can be controlled by TCP Wrappers. The main function of this tool is to control access of programs, such as rpcbind, vsftpd, sshd, and telnet.
After the upgrade, the rules in hosts.deny and hosts.allow become invalid.
For details, see the official document to remove unsupported configuration items.
zipl
Boot tool conflicts
Boot tool conflicts
During the upgrade from RHEL 7 to RHEL 8, the boot tool zSeries Initial Program Loader (zipl) of the IBM S/390 and zSeries architectures may have compatibility issues due to configurations, functions, or dependency changes. The core issues involve the syntax and option support of the /etc/zipl.conf configuration file and the adaptation to new system components. Some configuration items that are valid in RHEL 7 are removed from or renamed in RHEL 8. As a result, the original configurations become invalid.
  1. Some configuration file options are discarded, such as debug=1 and sectors=512. The zipl configuration verification fails, and the error message "invalid configuration" or "unknown option" is displayed.
  2. The boot device path is incompatible—it does not use the RHEL 8–recommended addressing schemes, such as UUID or /dev/disk/by-id paths.
  3. The image or ramdisk parameter points to the original kernel of RHEL 7, for example, vmlinuz-3.10.0. The kernel is not updated to RHEL 8 kernel (vmlinuz-4.18.0).
  4. The 512-byte sector (sectors=512) in RHEL 7 conflicts with the 4K sector disk supported by RHEL 8.
  5. The boot tool conflicts. The residual GRUB 2 in the system overwrites the zipl boot records.
  1. Delete obsolete options such as debug=1 and sectors=512.
  2. Obtain the new UUID and update the configuration.
  3. Update the image and ramdisk configurations.
    bash:
    sed -i "s|^image=.*|image=<RHEL 8-kernel-path>" /etc/zipl.conf
    sed -i "s|^ramdisk=.*|ramdisk=< initramfs-path>" /etc/zipl.conf
  4. Delete the forcible sector parameter sectors=512. bash:
    sed -i '/^sectors=512/d' /etc/zipl.conf
  5. Uninstall GRUB 2.
    bash:
    dnf remove grub2-common grub2-s390x
FILESYSTEM software package and file system mounting mechanism
If the ISO image is mounted to the /mnt directory, the filesystem software package upgrade will fail.
Image mounting errors
Run the mount command to mount the image file. When the ISO image is used as the source for system upgrade, do not mount the ISO image to the /mnt directory. Otherwise, the Filesystem software package upgrade will fail.
Check whether the system file is mounted to the /mnt directory. If yes, the system prompts you to unmount the file.
bash:
df -h | grep /mnt
Unmount the system files mounted to the /mnt directory.
bash:
umount /mnt
SELinux
SELinux rule differences
During the SELinux upgrade, the system modifies or replaces a large number of files and processes, which may conflict with the SELinux security policy. As a result, the upgrade is affected. For details, see official documents.
Run the getenforce command to check the SELinux mode.
bash:
getenforce
If the SELinux mode is Enforcing, change it to Permissive temporarily.
bash:
sudo setenforce 0
Files with special permissions
The logic of protecting files with special permissions conflicts with the operability requirements of files required for the upgrade. As a result, the upgrade may be interrupted.
Run the following command to query files with special permissions.
bash:
lsattr -alR ${dir} 2>/dev/null | grep -E "Append_Only|Immutable"
Replace ${dir} in the command with the following path:
  • /etc/*
  • /boot/*
  • /var/*
  • /run/*
  • /opt/sut/check_result/*
Manually modify the permission of the files with special permissions.
bash:
chattr -a -i <specific-file-name>
